Kenmore Front Load Washer Won't Spin
By**soye13**[1 Post]
0
Share
0
Save
Follow
More
I have a Kenmore front loading washer model # 41744052400 that won't spin. It will agitate and drain, but will only spin when I run the diagnostics. I replaced the door switch and the front control panel with used, but tested ones and still have the same problem. It does make a loud buzzing noise when it is supposed to spin, but it also makes this noise when I force the spin through diagnostics. I also have recently replaced the motor control board. I did notice that when I went into diagnostics with the original board the lights would flash in sequence through each station, with new board all the lights at each station will flash at once then move to next station. Any ideas?
