With the front off the washer the leak appears to be coming from the left rear portion of the washer around a 1" (approx) vertical tube hanging from the side of the tub. It leaks when the washer is filling and washing. I have no parts diagram to see what the vertical tube may be. Overflow?? Any Ideas??:confused:
