rebuilt the bearings in machine and it spins fine now however when I rotate the tub the tumblers on the transmission do not move. removed the transmission again turned the coupling in the transmission by hand and the tumblers move if I hold them they do not move at all and the shaft connection in the transmission just spins in place. When I place the transmission in the machine with the agitators in place same thing no movement. I ran the machine on a quick cycle and still no movement of the agitators. ran a load and I got a leak this time and still no movement. My questions are is it possible the transmission is bad or is it a alignment problem onto the spinner shaft? Also should I replace the seal on the transmission? thanks
