Trying to fix ge front load washer that is overfilling. i've torn it apart and have the pressure switch out for a resistance check
When I test for continuity I find it between all contacts with no pressure. When I apply pressure, no continuity is found between any contacts.
I'm not certain of the logic and this is why i'm asking but i'd expect with no pressure to have continuity on one pair and not the other and the reverse of that when pressure is applied.
Anyone familiar with what I should find?
Thank you
Jason
