My Kenmore He2 Washer Has A Balance Problem When In Spin Mode, I Checked The Rear Bearing Assembly For Looseness & It Seems Tight, I Am Wondering About The 3 Lower Shocks, They Are Not A Regular Shock Like On A Car, They Are A Square Plastic Tube Inside Another Square Plastic Tube With Some Rubber On The Outside Of The Inner Tube For Resistance I Assume. How Tight Should They Be To Control The Bounce Of The Drum??
