I just had a drain pump put in about 14 months ago. The warranty is no longer valid. When I start the washer it is supposed to go through a drain cycle first. I have the voltage from the wires going to the pump and they stay at 120 until the cycle is over. When I check the continuity of the pump is says there is continuity by beeping at me. From this information the Youtube video I watch says the pump is good. Is there something else I can check to make sure whether or not it is the pump?
