Groups ready for retrieval: Registered
Have a Kenmore oasis top load washer that is no longer completing a drain cycle. This originally started as a SD error. I've replaced the drain pump as the impeller on the old one was a little wobbly. but I am still having issues
I've done all the manual diagnostics and it passes every step.
What is happening is when it gets to a drain cycle it drains the tub. When the tub is empty, the drain pump keeps going and the agitator keeps rotating a 1/4 turn. Since drain pump is still going, I can hear little squirts of water coming out into my drain pipe and it sounds like it's cavitating. I did a tub zero reset and ran an agitation test; after the test I hit stop and it drained the tub and stopped immediately when empty so it seems the issue is only during a wash cycle. I think that narrows it down to the RPS (which passes the manual test) or the mainboard but I'm not sure which is the issue and would like some additional input
thanks
