Washer shuts off intermittently. I suspect the door switch. Where is it and how do I get the top off?
Joined: 6/13/2014(UTC) Posts: 781 Was thanked: 1 time(s) in 1 post(s)
We need the model number, the one listed is not correct. It should be listed on a tag under/inside the door along with the serial number.
