My 15+ year old Whirlpool washing machine GSQ9364HQ0 stopped spinning, it drains but won't spin. How do I determine if the issue is the neutral drain transmission or the basket drive, or something else?
Thank you
Joined: 6/13/2014(UTC) Posts: 781 Was thanked: 1 time(s) in 1 post(s)
Perhaps the coupler between the motor and transmission is broken. If that is the case then you can just replace it with a new one, however! Here is that part. Whirlpool 285753A Whirlpool Direct Drive Washer Motor Coupling - AppliancePartsPros.comThe however is why did it break? Old age? Something stuck between the basket and outer tub? Transmission neutral hold not working? This is most common! If so then fix it with Whirlpool 388253 Neutral Drain Kit - AppliancePartsPros.com here is a repair video https://www.youtube.com/watch?v=ieZ5y47TAMkThe easy way to test for neutral drain is, after replacing the coupler run a cycle with water level set to small. When the cycle begins to drain prior to rinse do you hear a clunk sound and detect that the barrel is spinning with water still in the tub? You see the neutral should allow the pump to drain the standing water from the tub, the timer will pause for a moment and then start back up engaging the transmission to spin. If that doesn't happen the weight of the water and clothes put extreme pressure on the coupler.
Thank you, I'll take it apart this weekend and find out.
