We are experiencing low speed vibration with the washer, less the 400 RPM, but it runs smooth at higher speeds. We had to replace the drum spider due to a crack and the outer rear tub. It now runs smooth at high speeds but still seems to vibrate excessively at lower speeds. The drum itself is not out of round or damaged.
