Discuss
Kenmore HE2 no lights
 in
Washer Repair
Kenmore HE2 was in the middle of a load and went completely blank on the front panel, won't turn on,
Appliance Repair Forum > Appliance Repair Help > Washer Repair » Kenmore HE2 no lights
  #1 (permalink)
Old 09-03-2016, 04:46 PM
Junior Member
saiber77 is on a distinguished road
Default Kenmore HE2 no lights
Model Number: 110.46462501   Brand: Kenmore   Age: 1 - 5 years
Kenmore HE2 was in the middle of a load and went completely blank on the front panel, won't turn on, nothing happens when I unplug for 30 seconds or more and plug it back in other than a 'CLICK' which seems to come from the front panel area. What part should I replace to fix this issue? I have seen all sorts of suggestions while searching the web ranging from CCU to MCU, to control panel... I'm confused, how do I diagnose this issue, can someone help me? Thanks.
Related Models
Hoover 1100
Kenmore 110088732791 WASHER/DRYER LAUNDRY SYSTEM
Magic Chef 1100PAA RANGE- F/S STD GAS
Magic Chef 1100PAW RANGE- F/S STD GAS
Magic Chef 1100PAW-K RANGE- F/S STD GAS
Magic Chef 1100PAW-KL RANGE- F/S STD GAS
Magic Chef 1100PAW-L RANGE- F/S STD GAS
Magic Chef 1100PRA RANGE- F/S STD GAS
Magic Chef 1100PRA-K RANGE- F/S STD GAS
Magic Chef 1100PRW RANGE- F/S STD GAS
Magic Chef 1100PRW-K RANGE- F/S STD GAS
Kenmore 11010202000 COMPACT WASHER
Kenmore 11010202001 WASHER
Kenmore 11010502990 AUTOMATIC WASHER
Kenmore 11010502991 AUTOMATIC WASHER, COMPACT A/W
Kenmore 11010852990 AUTOMATIC WASHER
Kenmore 11010852991 AUTOMATIC WASHER, COMPACT A/W
Kenmore 11012202100 WASHER
Kenmore 11012502100 AUTOMATIC WASHER, COMPACT A/W
Kenmore 11012852100 AUTOMATIC WASHER, COMPACT A/W
Kenmore 11013202200 WASHER
Kenmore 11013212200 AUTOMATIC WASHER
Kenmore 11014102300 AUTOMATIC WASHER
Kenmore 11014112300 AUTOMATIC WASHER
Kenmore 11014202300 AUTOMATIC WASHER
Kenmore 11014212200 AUTOMATIC WASHER
Kenmore 11014222300 AUTOMATIC WASHER
Kenmore 11014502300 AUTOMATIC WASHER
Kenmore 11014852300 AUTOMATIC WASHER
Kenmore 11015732400 WASHER
Kenmore 11015842400 WASHER
Kenmore 11015852400 WASHER
Kenmore 11015862400 WASHER
Kenmore 11015864400 WASHER
Kenmore 11015942400 RESIDENTIAL WASHER
Kenmore 11015942401 RESIDENTIAL WASHER
Kenmore 11015944400 RESIDENTIAL WASHER
Kenmore 11015944401 RESIDENTIAL WASHER
Kenmore 11015952400 RESIDENTIAL WASHER
Kenmore 11015952401 RESIDENTIAL WASHER
Kenmore 11015954400 RESIDENTIAL WASHER
Kenmore 11015954401 RESIDENTIAL WASHER
Kenmore 11015962400 RESIDENTIAL WASHER
Kenmore 11015962401 RESIDENTIAL WASHER
Kenmore 11015964400 RESIDENTIAL WASHER
Kenmore 11015964401 RESIDENTIAL WASHER
Kenmore 11016101690 AUTOMATIC WASHER
Kenmore 11016101691 AUTOMATIC WASHER
Kenmore 11016102500 WASHER
Kenmore 11016102501 RESIDENTIAL WASHER
Kenmore 11016102502 RESIDENTIAL WASHER
Kenmore 11016202690 WASHER
Kenmore 11016202691 AUTOMATIC WASHER
Kenmore 11016212500 WASHER
Kenmore 11016212501 WASHER
Kenmore 11016212502 RESIDENTIAL WASHER
Kenmore 11016212503 RESIDENTIAL WASHER
Kenmore 11016502690 WASHER
Kenmore 11016502691 AUTOMATIC WASHER
Kenmore 11016502692 AUTOMATIC WASHER
Kenmore 11016502693 AUTOMATIC WASHER
Kenmore 11016502694 AUTOMATIC WASHER
Kenmore 11016512690 WASHER
Kenmore 11016512691 AUTOMATIC WASHER
Kenmore 11016512692 AUTOMATIC WASHER
Kenmore 11016602690 AUTOMATIC WASHER
Kenmore 11016602691 AUTOMATIC WASHER
Kenmore 11016602692 AUTOMATIC WASHER
Kenmore 11016602693 AUTOMATIC WASHER
Kenmore 11016611690 AUTOMATIC WASHER
Kenmore 11016611691 AUTOMATIC WASHER
Kenmore 11016611692 AUTOMATIC WASHER
Kenmore 11016612690 AUTOMATIC WASHER
Kenmore 11016612691 AUTOMATIC WASHER
Kenmore 11016612692 AUTOMATIC WASHER
Kenmore 11016732500 WASHER
Kenmore 11016812500 WASHER
Kenmore 11016812501 WASHER
Kenmore 11016812502 RESIDENTIAL WASHER
Kenmore 11016812503 RESIDENTIAL WASHER
Kenmore 11016852500 WASHER
Kenmore 11016852501 WASHER
Kenmore 11016852502 WASHER
Kenmore 11016852503 WASHER
Kenmore 11016862500 RESIDENTIAL WASHER
Kenmore 11016862501 WASHER
Kenmore 11016862502 WASHER
Kenmore 11016862503 RESIDENTIAL WASHER
Kenmore 11016872690 WASHER
Kenmore 11016872691 AUTOMATIC WASHER
Kenmore 11016872692 AUTOMATIC WASHER
Kenmore 11016872693 AUTOMATIC WASHER
Kenmore 11016882500 RESIDENTIAL WASHER
Kenmore 11016882501 WASHER
Kenmore 11016882502 WASHER
Kenmore 11016882503 RESIDENTIAL WASHER
Kenmore 11016922500 WASHER
Kenmore 11016922501 RESIDENTIAL WASHER
Kenmore 11016922502 WASHER
Kenmore 11016922503 WASHER
Kenmore 11016922504 RESIDENTIAL WASHER
Kenmore 11016942500 WASHER
Kenmore 11016942501 WASHER
Kenmore 11016942502 WASHER
Kenmore 11016942503 RESIDENTIAL WASHERS
Kenmore 11016962500 WASHER
Kenmore 11016962501 WASHER
Kenmore 11016962502 WASHER
Kenmore 11016962503 RESIDENTIAL WASHERS
Kenmore 11016964500 WASHER
Kenmore 11016964501 WASHER
Kenmore 11016964502 WASHER
Kenmore 11016964503 RESIDENTIAL WASHERS
Kenmore 11016972500 WASHER
Kenmore 11016982500 WASHER
Kenmore 11016984500 WASHER
Kenmore 11016986500 WASHER
Kenmore 11017102700 RESIDENTIAL WASHER
Kenmore 11017122700 RESIDENTIAL WASHER
Kenmore 11017132700 RESIDENTIAL WASHER
  #2 (permalink)
Old 09-05-2016, 08:12 AM
Senior Member
brobriffin is on a distinguished road
Default
Although I tend to agree you might need to replace the CCU why not start from simple and work toward that end.
First (it may sound stupid) but are you getting true full 110/120 v to your machine? I know you said it clicks when you plug it back in but sillier things have happened.
Second Open the top and look to see if there are any obvious signs of a shorted wire coming from the electric connection to the control board. Look for burn marks signs of arcing etc.
Third (unplug power for this) unplug all connections to and from the control board. Try even to clean them as you do using a connector cleaner.
Do the same for the wires to and from the user interface.
If non of these actions correct the situation, then I'm afraid its time for a new CCU.
Whirlpool WPW10525355 Cntrl-Elec - AppliancePartsPros.com
  #3 (permalink)
Old 09-05-2016, 03:12 PM
Junior Member
Default
I haven't actually taken the CCU housing apart to look for arcing or burn marks nor have I tested the outlet to make sure it is true 110v, I'd have to grab a voltmeter to make sure. I did however do a basic visual inspection of the wiring and connections with the lid taken off and unplugged and re-seated all the connectors. Although the original button tabs that hold the CCU housing to the side of the washer broke off and it kind of hangs about it has no obvious signs of damage due to hanging there. I could try the electronic cleaner but I also have 99% rubbing alcohol and nylon brushes. I use that to sometimes fix motherboards and component boards in computers and laptops when there's water damage.
I've read that the click is a sign that the control panel is not the problem, can you confirm that this is so?
I used an extension cable to test other outlets and it still doesn't work, also if I unplug and re-plug pretty quickly I get one click. If I wait about 30 seconds I get two clicks, does that mean anything?
Thanks in advance.
  #4 (permalink)
Old 09-05-2016, 03:38 PM
Senior Member
Default
You may also try to unplug it for 5 to 10 minutes to clear any stored memory and plug it back in. If that's not it, then yes try your rubbing alcohol on both the wire terminals and the connectors on the CCU, as well as on the UI.
  #5 (permalink)
Old 09-05-2016, 03:47 PM
Senior Member
Default
One other possibility is that the noise filter may be bad.
Whirlpool WPW10367632 Noise Filter - AppliancePartsPros.com
Noise filter WPW10367632 filters the electrical power supply to prevent control board damage from power surges. This may be bad and the source of the clicking sound.
  #6 (permalink)
Old 09-17-2016, 12:23 PM
Junior Member
Default
Any way to test it? And thanks for all the help.
  #7 (permalink)
Old 09-17-2016, 01:02 PM
Senior Member
Default
Look at the top of the filter and it will list the ohms resistance and the microfarad ratings. You can use an advanced multi-meter to check. Or simply purchase a new one Whirlpool WPW10367632 Noise Filter - AppliancePartsPros.com
and try it. Everything you've said leans toward it being bad though.
  #8 (permalink)
Old 09-18-2016, 06:03 PM
Junior Member
Default
Testing the two bottom leads "N and L" gives between 1.36 and 1.42 μF (it fluctuates), same with the two center posts and combinations of inner/outer opposing posts.
ohms reading for two bottom leads "N and L" gives 468.4 kΩ and it climbs to 469.0 kΩ and stops. Opposing inner/outer leads the same. Same side inner/outer leads gives 0.2Ω
These are the readings I get, I have no idea how to make heads or tails of them, can you help? Thanks.
  #9 (permalink)
Old 09-18-2016, 08:08 PM
Senior Member
Default
Ok the 468 to 469 ohms are good however the microfarads are way out of proportion. If I am reading it correctly it should be .002 μf or +2x1000pf so replace the filter and all should be good.
Sorry I did not get back to you sooner but I was chasing Pokemon with the family this evening. Almost got a Snorlax. Wife got her fav peekatchu. LOL
  #10 (permalink)
Old 09-18-2016, 09:34 PM
Junior Member
Default
Ok, thanks for the reply. No worries on how long it took, I'm a patient man. My Son and I both have Snorlax, his is over 1k CP but mine is only about 600 CP or thereabouts. I guess I'll go ahead and order that part, wish me luck. lol.
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
kenmore dishwasher no lights flybynight62 Oven Repair (including Ranges and Cooktops) 3 10-14-2015 02:48 AM
Kenmore lights blinking arobint Dishwasher Repair 3 11-15-2013 07:30 AM
Kenmore Lights Flashing SliperyTom Dishwasher Repair 0 01-06-2013 12:35 PM
Kenmore Oven - Lights up but nothing else bartlejm Oven Repair (including Ranges and Cooktops) 0 11-16-2011 06:35 AM
No lights/flashing lights on Kenmore Elec Dryer ehull Dryer Repair 0 08-02-2008 01:10 PM
