I watched the great video from appliancepartspros to remove the gearcase. I want to change the clutch because it isn't spinning with heavy loads. Everything was exactly like the video but the gear case won't come out. It moved out about an inch or two but doesn't slide out like the video. http://forum.appliancepartspros...-loads-normal-cycle.htmlAny ideas or guidance on what is holding it in would be greatly appreciated. I have the new clutch assembly but can't get the drive train out. Thanks in advance.
