Discuss
GE Washer won't Agitate or Spin
 in
Washer Repair
Good morning, I have an 11+ year old washer that I am making a last ditch effort to save. I
Appliance Repair Forum > Appliance Repair Help > Washer Repair » GE Washer won't Agitate or Spin
  #1 (permalink)
Old 08-24-2016, 06:34 AM
Junior Member
peaches0605 is on a distinguished road
Default GE Washer won't Agitate or Spin
Model Number: WHSE5240D1WW   Brand: GE   Age: More than 10 years
Good morning,
I have an 11+ year old washer that I am making a last ditch effort to save. I have repaired the matching dryer many times.
Noticed that a load of clothes had not spun and were sitting soaking wet in the washer. I have done the following:
Removed the magnet from the lid so I was able to place it over the door switch and observe what's happening in the washer with the lid open.
Checked the clear tubing along the left side of the drum..it was clear. When I blew into the tube I could hear the clicking noise that I am apparently supposed to hear.
Checked all wires. Nothing loose.
Removed control panel on top of the washer (behind the knobs). No loose wiring there either.
Belt is intact and looks good.
Pump seems to be running fine.
I cannot find any LED lights on the motor. Perhaps this feature came after my old model? (purchased 2005)
Wiring to the door switch is intact; don't see any problems there.
Pulled out the agitator from the drum, unscrewed the bolt holding on the coupling, the coupling appeared fine upon inspection.
So like I stated above, when I start a cycle, the drum fills up normally. When it's time to agitate (observed with the lid up, magnet on the door switch to enable agitation/spinning to work), no agitation happens. I hear a slight humming sound. Then when it's time to drain, the water drains out, and when it's time to spin, no spinning happens (again, the same slight humming sound).
I don't observe the belt rotating at all. Does the belt control the motor or does the motor control the belt?
If I need a new motor, I'll definitely just go for a new washer. But if it's something simple I'm missing, I'm willing to try.
Thanks for any help you can provide!
Related Models
General Electric WHSE5240D1WW Washer
General Electric WHSE5240DCCC Washer
General Electric WHSE5240DCWW Washer
General Electric WHSR2070V2WB Washer
General Electric WHSR2070V3WB Washer
General Electric WICB103CV1WC Washer
Frigidaire WIDH3 Frg(v18) / Top Loading Washer
Frigidaire WIDH4 Frg(v3) / Top Load Washer
Frigidaire WIDL3 Frg(v19) / Top Loading Washer
Frigidaire WIDL4 Frg(v2) / Top Load Washer
Frigidaire WIDW3 Frg(v20) / Top Loading Washer
Frigidaire WIDW4 Frg(v1) / Top Load Washer
Frigidaire WILH1 Frg(v2) / 27 " Washer
Frigidaire WILL0 Frg(v2) / 27 " Washer
Frigidaire WILL1 Frg(v3) / 27 " Washer
Frigidaire WILW0 Frg(v1) / 27 " Washer
Frigidaire WILW1 Frg(v1) / 27 " Washer
Frigidaire WIMA1 Frg(v16) / Washer
Frigidaire WIMA2 Frg(v17) / Washer
Frigidaire WIMA3 Frg(v15) / Washer
Frigidaire WIMF1 Frg(v18) / Washer
Frigidaire WIMF2 Frg(v19) / Washer
Frigidaire WIMF3 Frg(v16) / Washer
Frigidaire WIMH1 Frg(v20) / Washer
Frigidaire WIMH2 Frg(v21) / Washer
Frigidaire WIMH3 Frg(v17) / Washer
Frigidaire WIML1 Frg(v22) / Washer
Frigidaire WIML2 Frg(v23) / Washer
Frigidaire WIML3 Frg(v18) / Washer
Frigidaire WIMW1 Frg(v24) / Washer
Frigidaire WIMW2 Frg(v25) / Washer
Frigidaire WIMW3 Frg(v19) / Washer
Frigidaire WISCL2 Frg(v3) / Washer
Frigidaire WISCL3 Frg(v3) / Washer
Frigidaire WISCL5 Frg(v3) / Top Loading Washer
Frigidaire WISCL6 Frg(v4) / Top Load Washer
Frigidaire WISCLL0 Frg(v4) / 27 " Washer
Frigidaire WISCLL1 Frg(v6) / 27 " Washer
Frigidaire WISCLL2 Frg(v2) / 27 " Washer
Frigidaire WISCLW0 Frg(v3) / 27 " Washer
Frigidaire WISCLW1 Frg(v4) / 27 " Washer
Frigidaire WISCLW2 Frg(v1) / 27 " Washer
Frigidaire WISCW2 Frg(v4) / Washer
Frigidaire WISCW3 Frg(v4) / Washer
Frigidaire WISCW5 Frg(v4) / Top Loading Washer
Frigidaire WISCW6 Frg(v3) / Top Load Washer
Frigidaire WISDL2 Frg(v21) / Top Loading Washer
Frigidaire WISDL3 Frg(v5) / Top Load Washer
Frigidaire WISDLL0 Frg(v6) / 27 " Washer
Frigidaire WISDLL1 Frg(v9) / 27 " Washer
Frigidaire WISDLW0 Frg(v5) / 27 " Washer
Frigidaire WISDLW1 Frg(v7) / 27 " Washer
Frigidaire WISDW2 Frg(v22) / Top Loading Washer
Frigidaire WISDW3 Frg(v4) / Top Load Washer
General Electric WISQ416AT5WW Washer
General Electric WISQ416AT6WW Washer
General Electric WISQ416AT7WW Washer
General Electric WISQ416AT8WW Washer
General Electric WISQ416ATAWW Washer
General Electric WISQ416BT5WW Washer
General Electric WISQ416BT6WW Washer
General Electric WISQ416BT7WW Washer
General Electric WISQ416BT8WW Washer
General Electric WISQ416BTAWW Washer
General Electric WISQ416CT5WW Washer
General Electric WISQ416CT6WW Washer
General Electric WISQ416CT7WW Washer
General Electric WISQ416CT8WW Washer
General Electric WISQ416CTAWW Washer
General Electric WISQ416DT5WW Washer
General Electric WISQ416DT6WW Washer
General Electric WISQ416DT7WW Washer
General Electric WISQ416DT8WW Washer
General Electric WISQ416DTAWW Washer
General Electric WISQ416FT8WW WASHER
General Electric WISQ416FTAWW Washer
General Electric WISQ416JT5AA Washer
General Electric WISQ416JT6AA Washer
General Electric WISQ416JT7AA Washer
General Electric WISQ416JT8AA Washer
General Electric WISQ416JTAAA Washer
General Electric WISR106CT5WW Washer
General Electric WISR106DGBWW Washer
General Electric WISR106DGCWW WASHER
General Electric WISR106DGDWW WASHER
General Electric WISR106DT5WW Washer
General Electric WISR106DT8WW Washer
General Electric WISR106DTAWW Washer
General Electric WISR106DTBWW Washer
General Electric WISR106HT8WW Washer
General Electric WISR106HTAWW Washer
General Electric WISR208JT5AA Washer
General Electric WISR208JT6AA Washer
General Electric WISR208JT8AA Washer
General Electric WISR208JTAAA Washer
General Electric WISR309CT5WW Washer
General Electric WISR309CT6WW Washer
General Electric WISR309CT8WW Washer
General Electric WISR309CTAWW Washer
General Electric WISR309DGBWW Washer
General Electric WISR309DGCWW WASHER
General Electric WISR309DGDWW WASHER
General Electric WISR309DT5WW Washer
General Electric WISR309DT6WW Washer
General Electric WISR309DT8WW Washer
General Electric WISR309DTAWW Washer
General Electric WISR309DTBWW Washer
General Electric WISR409DGBWW Washer
General Electric WISR409DGCWW WASHER
General Electric WISR409DGDWW WASHER
General Electric WIST208JT5WW Washer
General Electric WIST208JT6WW Washer
General Electric WIST208JT8WW Washer
General Electric WIST208JTAWW Washer
General Electric WJRE5500G0WW Washer
General Electric WJRE5500G1WW WASHER
General Electric WJRE5500G2WW WASHER
General Electric WJRE5500G3WW WASHER
General Electric WJRE5500K0WW WASHER
General Electric WJRE5500K1WW WASHER
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
GE washer won't spin/agitate Mlsmith Washer Repair 1 10-09-2013 02:52 PM
washer won't spin or agitate ctaylor4305 Washer Repair 4 11-19-2011 07:26 AM
Kenmore Washer Won't Spin,Agitate,or Spin (Will Fill) cowboys#1 Washer Repair 8 01-13-2011 10:13 AM
Washer will agitate but not spin/spin slowly sainthooligan Washer Repair 11 07-24-2010 10:34 AM
Washer won't agitate or spin Russel Washer Repair 3 08-03-2009 07:10 AM
