Discuss
Drain Pump Noise - Frigidaire Affinity Front Load Washer
 in
Washer Repair
I have a Frigidaire front load washer that is working fine, but makes a loud vibrating noise when draining. First
Appliance Repair Forum > Appliance Repair Help > Washer Repair » Drain Pump Noise - Frigidaire Affinity Front Load Washer
  #1 (permalink)
Old 08-19-2016, 07:16 AM
Junior Member
mschlott is on a distinguished road
Default Drain Pump Noise - Frigidaire Affinity Front Load Washer
Brand: Frigidaire   Age: Less than 1 year
First question. Is the drain pump supposed to run the entire time during the spin cycle. Mine does even after the water is drained.
From reading the forum, I see that this problem is usually caused by a blocked filter, something stuck in the pump or a bad pump.
I took the pump out and inspected it and did not see anything in it. I connected it to 110v and let it run while sitting on the floor and it was very quiet. I removed the rubber boot that feeds into the pump. It had some lint caught in it but not enough to obstruct the flow.
I cleaned out the boot thoroughly and re-assembled everything. After putting it back together the noise is still there.
The only strange thing I noticed is that the check valve on the pump looked like it was too big for the opening. Since it was not damaged in any way, I assumed it was correct.
I am hesitant to replace the pump because it runs so quietly outside of the washer. Is there something I forgot to check?
Is there some way I can make the drain pump run with the front door panel removed?
mike
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
Frigidaire Affinity Front Load Washer Problem mommamurray13 Washer Repair 0 03-18-2014 12:16 PM
Frigidaire Affinity Front Load Washer Won't Start - Error Code E6F elkoell Washer Repair 0 12-04-2013 02:37 PM
frigidaire front load washer water pump efrain Washer Repair 4 09-05-2010 07:27 AM
Frigidaire Gallery Front Load Washer Pump Mabsnow Washer Repair 1 04-10-2008 01:29 PM
