Discuss
maytag washer lights blink
 in
Washer Repair
All the lights around the control dial will bink twice every couple of minutes. When you start to fill it,
Appliance Repair Forum > Appliance Repair Help > Washer Repair » maytag washer lights blink
  #1 (permalink)
Old 11-01-2009, 07:32 PM
alextr alextr is offline
Junior Member
alextr is on a distinguished road
Default maytag washer lights blink
Model Number: mav5920eww   Brand: Maytag   Age: 1 - 5 years
All the lights around the control dial will bink twice every couple of minutes. When you start to fill it, it will fill for about 30 seconds then stop and the lights blink twice. I cleaned the filters in the end of the hoses, are there filters in the water valve too?
I have unplugged it to try reset no change. Also when you put it on spin, it will spin for a little while then lights up and quits.
Also as soon as I plug it in all the light blink twice.
Thank you;
Leo
Related Models
Maytag MAV5920EWW Washer - Top Loading
Maytag MAV5960AWW Washer, Atlantis
Maytag MAV6000AWQ Washer, Atlantis
Maytag MAV6000AWW Washer, Atlantis
Maytag MAV6057AWQ Washer, Atlantis
Maytag MAV6057AWW Washer, Atlantis
Maytag MAV6200AWQ Washer, Atlantis
Maytag MAV6200AWW Washer, Atlantis
Maytag MAV6250AWQ Washer, Atlantis
Maytag MAV6250AWW Washer, Atlantis
Maytag MAV6257AWQ Washer, Atlantis
Maytag MAV6257AWW Washer, Atlantis
Maytag MAV6260AWW Washer, Atlantis
International MAV6300AGW Washer - Top Loading
Maytag MAV6300AWQ Washer, Atlantis
Maytag MAV6300AWW Washer, Atlantis
International MAV6300BGW Washer - Top Loading
International MAV6300CGW Washer - Top Loading
Maytag MAV6357AWW Washer, Atlantis
Maytag MAV6358AWW Washer, Atlantis
Maytag MAV6451AGW Washer, Atlantis
Maytag MAV6451AWQ Washer, Atlantis
Maytag MAV6451AWW Washer, Atlantis
Maytag MAV6457AWW Washer, Atlantis
Maytag MAV6458AWW Washer, Atlantis
Maytag MAV6548AWQ Washer, Atlantis
Maytag MAV6548AWW Washer, Atlantis
Maytag MAV6601AWQ Washer, Atlantis
Maytag MAV6601AWW Washer, Atlantis
Maytag MAV6650AWW Washer, Atlantis
Maytag MAV7000AWQ Washer, Atlantis
Maytag MAV7000AWW Washer, Atlantis
Maytag MAV7057AWQ Washer, Atlantis
Maytag MAV7057AWW Washer, Atlantis
Maytag MAV7200AWQ Washer, Atlantis
Maytag MAV7200AWW Washer, Atlantis
Maytag MAV7257AWQ Washer, Atlantis
Maytag MAV7257AWW Washer, Atlantis
Maytag MAV7258AWQ Washer, Atlantis
Maytag MAV7258AWW Washer, Atlantis
Maytag MAV7260AWW Washer, Atlantis
Maytag MAV7260BWW Washer, Atlantis
Maytag MAV7357AWQ Washer, Atlantis
Maytag MAV7357AWW Washer, Atlantis
Maytag MAV7358AWQ Washer, Atlantis
Maytag MAV7358AWW Washer, Atlantis
Maytag MAV7450AWQ Washer, Atlantis
Maytag MAV7450AWW Washer, Atlantis
Maytag MAV7501EWW Washer, Atlantis
Maytag MAV7504EWW Washer, Atlantis
Maytag MAV7550AWQ Washer, Atlantis
Maytag MAV7550AWW Washer, Atlantis
Maytag MAV7551AWQ Washer, Atlantis
Maytag MAV7551AWW Washer, Atlantis
Maytag MAV7557EWQ Washer, Atlantis
Maytag MAV7557EWW Washer, Atlantis
Maytag MAV7580EWQ Washer, Atlantis
Maytag MAV7580EWW Washer, Atlantis
International MAV7600ACQ Washer - Top Loading
International MAV7600AGW Washer - Top Loading
Maytag MAV7600AWQ Washer, Atlantis
Maytag MAV7600AWW Washer, Atlantis
International MAV7600BGW Washer - Top Loading
International MAV7600CGW Washer - Top Loading
Maytag MAV7650AWQ Washer, Atlantis
Maytag MAV7650AWW Washer, Atlantis
Maytag MAV7657EWQ Washer, Atlantis
Maytag MAV7657EWW Washer, Atlantis
Maytag MAV7700AWQ Washer, Atlantis
Maytag MAV7700AWW Washer, Atlantis
International MAV7750AGW Washer - Top Loading
International MAV7750BGW Washer - Top Loading
International MAV7750CGW Washer - Top Loading
Maytag MAV7757AWQ Washer, Atlantis
Maytag MAV7757AWW Washer, Atlantis
Maytag MAV8000AWQ Washer, Atlantis
Maytag MAV8000AWW Washer, Atlantis
Maytag MAV8057AWQ Washer, Atlantis
Maytag MAV8057AWW Washer, Atlantis
Maytag MAV8260AWQ Washer, Atlantis
Maytag MAV8260AWW Washer, Atlantis
Maytag MAV8500AWA Washer, Atlantis
Maytag MAV8500AWQ Washer, Atlantis
Maytag MAV8500AWW Washer, Atlantis
Maytag MAV8551AWQ Washer, Atlantis
Maytag MAV8551AWW Washer, Atlantis
Maytag MAV8557AWQ Washer, Atlantis
Maytag MAV8557AWW Washer, Atlantis
Maytag MAV8600AWQ Washer, Atlantis
Maytag MAV8600AWW Washer, Atlantis
Maytag MAV8601AWQ Washer, Atlantis
Maytag MAV8601AWW Washer, Atlantis
Maytag MAV8757AWQ Washer, Atlantis
Maytag MAV8757AWW Washer, Atlantis
Maytag MAV9501EWQ Washer, Atlantis
Maytag MAV9501EWW Washer, Atlantis
Maytag MAV9504EWQ Washer, Atlantis
Maytag MAV9504EWW Washer, Atlantis
Maytag MAV9557EWQ Washer, Atlantis
Maytag MAV9557EWW Washer, Atlantis
Maytag MAV9600EWQ Washer, Atlantis
Maytag MAV9600EWW Washer, Atlantis
Maytag MAV9657EWQ Washer, Atlantis
Maytag MAV9657EWW Washer, Atlantis
Maytag MAV9750AGW Washer, Atlantis
Maytag MAV9750AWQ Washer, Atlantis
Maytag MAV9750AWW Washer, Atlantis
Maytag MAVT236AWW Washer - Top Loading
Maytag MAVT346AWW Washer - Top Loading
Maytag MAVT446AWW Washer - Top Loading
Maytag MAVT546EWW Washer - Top Loading
Maytag MAVT634AWW Washer, Atlantis
Maytag MAVT734EWW Washer, Atlantis
Maytag MAVT754EWW Washer, Atlantis
Maytag MAVT834AWQ Washer, Atlantis
Maytag MAVT834AWW Washer, Atlantis
Whirlpool MB1110SLQ Microwave Oven 1.1 Cubic Foot
International MB1927PEHB  Ref - Maytag Int'l Bot Mount
International MB1927PEHW  Ref - Maytag Int'l Bot Mount
International MB2216PUAW Ref - Bottom Mounts
  #2 (permalink)
Old 11-03-2009, 05:02 PM
sidfink43 sidfink43 is offline
Senior Expert
APP Volunteer
sidfink43 is on a distinguished road
Default
Try to find out if there is a problem in the wiring from the power supply into the control board and then inspect the rest of the wiring. If you do not find a problem I suggest replacing the control board, not because I know that is the problem but because I cannot think of anything else which can be causing your problem.
'Here is the part.
Part number: AP4025155
__________________
  #3 (permalink)
Old 11-06-2009, 07:56 AM
Junior Member
Default
Thanks for the reply, I was thinking the encoder switch or control board.
I changed out the control board and the wife is happy now.
Leo
  #4 (permalink)
Old 11-06-2009, 08:09 AM
Senior Expert
APP Volunteer
Default
Great, that makes all of us happy! Thanks for the update.
__________________
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
Frigidaire Model FDB2000RFB1 will not start. Lights continually blink. wesley.barbour Dishwasher Repair 0 03-02-2009 11:30 AM
maytag has dim lights on juan Dishwasher Repair 0 04-18-2008 08:41 AM
Maytag control pad on the blink (again) CCB Dishwasher Repair 3 02-14-2008 06:30 PM
Maytag humming, lights blink, won't turn off mbardill Dishwasher Repair 0 02-12-2008 05:59 PM
Maytag dishwasher on the blink Sandra Dishwasher Repair 0 10-21-2007 11:42 AM
