I had a dc code and found information on this forum about issues with the clutch on this machine. I followed the instructions on cleaning the clutch bearings and it worked great for several loads after the repair, then I got the code again. I pulled the clutch again and the pin in the spring coil had come out and the end of the coil was bent. I straightened it and put it back and it worked for a couple of more loads but now something is bending the spring coil completely out of shape and the machine sounds like its falling apart.
Joined: 6/13/2014(UTC) Posts: 781 Was thanked: 1 time(s) in 1 post(s)
