Discuss
Washer won't agitate
 in
Washer Repair
This washer won't agitate. It fills, spins, drains, and everything else works great, just no agitate. So, waterlevel switch
Appliance Repair Forum > Appliance Repair Help > Washer Repair » Washer won't agitate
  #1 (permalink)
Old 11-01-2009, 12:50 PM
spthomas spthomas is offline
Junior Member
spthomas is on a distinguished road
Default Washer won't agitate
Model Number: LAT8035AAE   Brand: Maytag   Age: 1 - 5 years
This washer won't agitate. It fills, spins, drains, and everything else works great, just no agitate. So, waterlevel switch didn't test exactly right so I replaced it. Still no agitate. BUT, I thought I might have it wired wrong (there are 3 wires on the water level switch), so I tried different combinations. One combination did agitate (but at times when it should have been filling!). So, this confirmed to me that the agitation system does work (transmission, gears, etc.). And, the lid switch appears to work; when it's spinning if I lift the lid, it stops.
If I manually cycle the timer to the beginning of a cycle, it starts to fill, then stops filling at the end of the fill cycle. Next is an agitate cycle, and there nothing happens. If I manually forward the time to the spin cycle, that works and the water drains. And if I lift the lid, the spin stops, but when I close the lid it resumes.
So, water level pressure switch is new and works, transmission works, agitator gears are ok, lid switch works, fill and drain valves etc. work. The only thing not working is agitation, and it does NOTHING during agitation (no noises, etc.).
Any ideas?
Related Models
Maytag LAT8035AAE Washer - Top Loading
Maytag LAT8035AAM Washer - Top Loading
Maytag LAT8100AAL Washer - Top Loading
Maytag LAT8100AAW Washer - Top Loading
Maytag LAT8100ABL Washer - Top Loading
Maytag LAT8100ABW Washer - Top Loading
Maytag LAT8104AAE Washer - Top Loading
Maytag LAT8104AAL Washer - Top Loading
Maytag LAT8104AAM Washer - Top Loading
Maytag LAT8106AAE Washer - Top Loading
Maytag LAT8106ABE Washer - Top Loading
Maytag LAT8120AAL Washer - Top Loading
Maytag LAT8120AAW Washer - Top Loading
Maytag LAT8140AAL Washer - Top Loading
Maytag LAT8140AAW Washer - Top Loading
Maytag LAT8140ABL Washer - Top Loading
Maytag LAT8140ABW Washer - Top Loading
Maytag LAT8140ABX Washer - Top Loading
Maytag LAT8200AAL Washer - Top Loading
Maytag LAT8200AAW Washer - Top Loading
Maytag LAT8200ABL Washer - Top Loading
Maytag LAT8200ABW Washer - Top Loading
Maytag LAT8200ABX Washer - Top Loading
Maytag LAT8204AAE Washer - Top Loading
Maytag LAT8204AAL Washer - Top Loading
Maytag LAT8204AAM Washer - Top Loading
Maytag LAT8204ABE Washer - Top Loading
Maytag LAT8206AAE Washer - Top Loading
Maytag LAT8206AAM Washer - Top Loading
Maytag LAT8206ABE Washer - Top Loading
Maytag LAT8210AAL Washer - Top Loading
Maytag LAT8210AAW Washer - Top Loading
Maytag LAT8214AAE Washer - Top Loading
Maytag LAT8214AAL Washer - Top Loading
Maytag LAT8214AAM Washer - Top Loading
Maytag LAT8214ABE Washer - Top Loading
Maytag LAT8216AAE Washer - Top Loading
Maytag LAT8216AAM Washer - Top Loading
Maytag LAT8226AAE Washer - Top Loading
Maytag LAT8226AAM Washer - Top Loading
Maytag LAT8226ABE Washer - Top Loading
Maytag LAT8234AAE Washer - Top Loading
Maytag LAT8234AAL Washer - Top Loading
Maytag LAT8234AAM Washer - Top Loading
Maytag LAT8234ABE Washer - Top Loading
Maytag LAT8240AAL Washer - Top Loading
Maytag LAT8240AAW Washer - Top Loading
Maytag LAT8240ABL Washer - Top Loading
Maytag LAT8240ABW Washer - Top Loading
Maytag LAT8240ABX Washer - Top Loading
Maytag LAT8305AAE Washer - Top Loading
Maytag LAT8306AAE Washer - Top Loading
Maytag LAT8306AAM Washer - Top Loading
Maytag LAT8306ABE Washer - Top Loading
Maytag LAT8340AAL Washer - Top Loading
Maytag LAT8340AAW Washer - Top Loading
Maytag LAT8404AAE Washer - Top Loading
Maytag LAT8404AAL Washer - Top Loading
Maytag LAT8404AAM Washer - Top Loading
Maytag LAT8404ABE Washer - Top Loading
Maytag LAT8405AAE Washer - Top Loading
Maytag LAT8405AAM Washer - Top Loading
Maytag LAT8406AAE Washer - Top Loading
Maytag LAT8406AAM Washer - Top Loading
Maytag LAT8414AAE Washer - Top Loading
Maytag LAT8414AAL Washer - Top Loading
Maytag LAT8414AAM Washer - Top Loading
Maytag LAT8414ABE Washer - Top Loading
Maytag LAT8415AAE Washer - Top Loading
Maytag LAT8415AAM Washer - Top Loading
Maytag LAT8416AAE Washer - Top Loading
Maytag LAT8416AAM Washer - Top Loading
Maytag LAT8420AAL Washer - Top Loading
Maytag LAT8420AAW Washer - Top Loading
Maytag LAT8420ABL Washer - Top Loading
Maytag LAT8420ABW Washer - Top Loading
Maytag LAT8424AAE Washer - Top Loading
Maytag LAT8424AAL Washer - Top Loading
Maytag LAT8424AAM Washer - Top Loading
Maytag LAT8426AAE Washer - Top Loading
Maytag LAT8426AAM Washer - Top Loading
Maytag LAT8426ABE Washer - Top Loading
Maytag LAT8434AAE Washer - Top Loading
Maytag LAT8434AAL Washer - Top Loading
Maytag LAT8434AAM Washer - Top Loading
Maytag LAT8434ABE Washer - Top Loading
Maytag LAT8435AAE Washer - Top Loading
Maytag LAT8435AAM Washer - Top Loading
Maytag LAT8440AAL Washer - Top Loading
Maytag LAT8440AAW Washer - Top Loading
Maytag LAT8440ABL Washer - Top Loading
Maytag LAT8440ABW Washer - Top Loading
Maytag LAT8500AAL Washer - Top Loading
Maytag LAT8500AAW Washer - Top Loading
Maytag LAT8500ABL Washer - Top Loading
Maytag LAT8500ABW Washer - Top Loading
Maytag LAT8504AAE Washer - Top Loading
Maytag LAT8504AAL Washer - Top Loading
Maytag LAT8504AAM Washer - Top Loading
Maytag LAT8506AAE Washer - Top Loading
Maytag LAT8506AAM Washer - Top Loading
Maytag LAT8506ABE Washer - Top Loading
Maytag LAT8520AAL Washer - Top Loading
Maytag LAT8520AAW Washer - Top Loading
Maytag LAT8520ABL Washer - Top Loading
Maytag LAT8520ABW Washer - Top Loading
Maytag LAT8520BAL Washer - Top Loading
Maytag LAT8520BAW Washer - Top Loading
Maytag LAT8520BBL Washer - Top Loading
Maytag LAT8520BBW Washer - Top Loading
Maytag LAT8600AAE Washer - Top Loading
Maytag LAT8600AAL Washer - Top Loading
Maytag LAT8600AAW Washer - Top Loading
Maytag LAT8600ABE Washer - Top Loading
Maytag LAT8600ABL Washer - Top Loading
Maytag LAT8600ABW Washer - Top Loading
Maytag LAT8604AAE Washer - Top Loading
Maytag LAT8604AAL Washer - Top Loading
Maytag LAT8604AAM Washer - Top Loading
Maytag LAT8606AAE Washer - Top Loading
  #2 (permalink)
Old 11-01-2009, 06:20 PM
denman denman is offline
Senior Expert
APP Volunteer
denman will become famous soon enough
Default
Here are your parts, includes a wiring diagram
Replacement parts for MAYTAG LAT8035AAE | AppliancePartsPros.com
I would check this.
What you know is that the normally closed contacts (7/15) are closed and that they open when the washer is full.
What you do not know is if the normally open contacts (7/16) close when the unit is full.
If you have a meter. let the unit fill, unplug the unit and measure across the normally open contacts, should be 0 ohms.
Remember to remove a wire from either 7 or 16, this prevents you from reading an alternate/parallel circuit path.
__________________
  #3 (permalink)
Old 11-01-2009, 08:55 PM
Junior Member
Default
Thanks for the reply. When I went to my daughters house (it is her washer) I did npt have my meter handy, so I just installed the part. I will check that when I get back home this week.
But, since it seems likely that this brand new part is working right, is there anything else that could likely cause it to do everything but agitate? I should be prepared for more than one failure mode when I get there.
  #4 (permalink)
Old 11-02-2009, 05:32 AM
Senior Expert
APP Volunteer
Default
I cannot think of anything because you had it agitating which indicates the timer, motor etc is OK. So you really will not be able to tell until you troubleshoot further.
__________________
  #5 (permalink)
Old 11-04-2009, 09:11 PM
Junior Member
Default
Hmmm. Ok, a recap thinking this through. Timer turns, door switch works, but when the timer is on agitate cycle, nothing. No noise, no trying to turn or slipping. Acts like it's just not getting the signal to agitate. Then, when timer advances to Spin, it spins and drains, refills, then again nothing during agitate cycle. Pressure switch replaced. And if I switch around wires on the pressure switch I find a combination that makes it agitate (during what would be the fill cycle). But when wired properly, nothing. It really seems like an electrical problem, since it doesn't appear to be even trying to agitate. Is there another switch, like lid check switch, or the imbalance switch or something?
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
My washer won't agitate Senteya Washer Repair 1 07-17-2009 10:53 AM
stackable washer dryer: washer will not agitate jennypatterson Dryer Repair 0 03-04-2009 12:08 PM
Washer won't agitate b_radnc Washer Repair 1 02-20-2009 05:39 PM
Washer will not agitate dveljko Washer Repair 13 11-20-2008 12:11 PM
Washer will not agitate oogp1 Washer Repair 10 03-12-2008 05:33 PM
