I bought this used replaced the motor and motor control and repaired main board had a problem with the pressure switch and changed out the air hose ran for two or three loads just fine now it fills part way. It agitates but does not go into high-speed spin timer runs through the last Cycles in 5 minutes and does not shut off?
