Discuss
maytag atlantis spins but not agitate
 in
Washer Repair
First off the appliancepartspros website has been a real help with diagnosis and videos of how to repair a clothes
Appliance Repair Forum > Appliance Repair Help > Washer Repair » maytag atlantis spins but not agitate
  #1 (permalink)
Old 07-17-2016, 06:14 PM
Junior Member
femtnmax is on a distinguished road
Default maytag atlantis spins but not agitate
Model Number: mav6000aww   Brand: Maytag   Age: More than 10 years
First off the appliancepartspros website has been a real help with diagnosis and videos of how to repair a clothes washer. This washer has been very reliable, year 1999, top load, no lid lock, no pause button. It has been used several times per week since new.
Problem was the washer would fill, spin, but not agitate. This is my first time taking one apart. Inspection showed the plastic agitator splines were ok, the belt, electric motor, and transmission drive pulley cam/spline were also ok. From below when turning the belt cw then ccw rotation, the machine would agitate at first or not at all.
With help from this website I decided the problem must be the transmission. Parts I replaced included the transmission, brake rotor (had cracks in the casting), the belt had one crack starting, and decided to upgrade the transmission drive pulley/thrust bearing. For the cost we decided it was still worth it to repair the machine.
Tear down summary: removed top w/ lid, front and rear panels, agitator, inner tub, then outer tub had notches so could remove it before taking out the inner tub Hub.
Could not remove the inner tub hub with pipe wrench and hammer, so cut hub with cutoff wheel. Before cutting removed water pump and electric motor to keep them free of metal chips. Only cut notch in upper half of hub. Third cut was within 1/8 inch or so of hub threads, then chisel several deep "cuts" parallel with transmission axis. Hub turned off by hand.
Removed bottom pulley/cam, then trans/brake assy came out. To remove brake rotor attached three 4 inch C-clamps equal spaced around brake stator, then removed 3 of the 6 original bolts, threaded in 1 1/4 inch long temporary bolts, then removed last 3 original bolts, then slowly started opening the 3 C-clamps equal amounts. The clamps were loose about the time the temporary bolts were near the end of their threads.
Assembly in reverse order.
Brake rotor installed the long temporary bolts, clamped the rotor/stator together, then 3 original bolts, then removed temp bolts, then install last 3 original bolts, snug them down and remove c-clamps. Installed transmission into washer. Tightened upper seal/hub with 10 inch pipe wrench and gentle taps with hammer until snug. Then installed outer tub, inner tub, motor, pump, agitator, top panel with lid, etc.
Test ran the washer with front panel removed. There was a slight leak where water outlet hose attaches to the water pump. Cleaned the hose/pump connection, coated both pieces with plumbers slow set putty, reassembled with original clamp.
2nd test run no leaks...machine working fine again.
Related Models
Maytag MAV6000AWW WASHER, ATLANTIS
Maytag MAV6057AWQ WASHER, ATLANTIS
Maytag MAV6057AWW WASHER, ATLANTIS
Maytag MAV6200AWQ WASHER, ATLANTIS
Maytag MAV6200AWW WASHER, ATLANTIS
Maytag MAV6250AWQ WASHER, ATLANTIS
Maytag MAV6250AWW WASHER, ATLANTIS
Maytag MAV6257AWQ WASHER, ATLANTIS
Maytag MAV6257AWW WASHER, ATLANTIS
Maytag MAV6260AWW WASHER, ATLANTIS
Admiral MAV6300AGW WASHER-TOP LOADING
Maytag MAV6300AWQ WASHER, ATLANTIS
Maytag MAV6300AWW WASHER, ATLANTIS
Admiral MAV6300BGW WASHER-TOP LOADING
Admiral MAV6300CGW WASHER-TOP LOADING
Maytag MAV6357AWW WASHER, ATLANTIS
Maytag MAV6358AWW WASHER, ATLANTIS
Maytag MAV6451AGW WASHER, ATLANTIS
Maytag MAV6451AWQ WASHER, ATLANTIS
Maytag MAV6451AWW WASHER, ATLANTIS
Maytag MAV6457AWW WASHER, ATLANTIS
Maytag MAV6458AWW WASHER, ATLANTIS
Maytag MAV6548AWQ WASHER, ATLANTIS
Maytag MAV6548AWW WASHER, ATLANTIS
Maytag MAV6601AWQ WASHER, ATLANTIS
Maytag MAV6601AWW WASHER, ATLANTIS
Maytag MAV6650AWW WASHER, ATLANTIS
Maytag MAV7000AWQ WASHER, ATLANTIS
Maytag MAV7000AWW WASHER, ATLANTIS
Maytag MAV7057AWQ WASHER, ATLANTIS
Maytag MAV7057AWW WASHER, ATLANTIS
Maytag MAV7200AWQ WASHER, ATLANTIS
Maytag MAV7200AWW WASHER, ATLANTIS
Maytag MAV7257AWQ WASHER, ATLANTIS
Maytag MAV7257AWW WASHER, ATLANTIS
Maytag MAV7258AWQ WASHER, ATLANTIS
Maytag MAV7258AWW WASHER, ATLANTIS
Maytag MAV7260AWW WASHER, ATLANTIS
Maytag MAV7260BWW WASHER, ATLANTIS
Maytag MAV7357AWQ WASHER, ATLANTIS
Maytag MAV7357AWW WASHER, ATLANTIS
Maytag MAV7358AWQ WASHER, ATLANTIS
Maytag MAV7358AWW WASHER, ATLANTIS
Maytag MAV7450AWQ WASHER, ATLANTIS
Maytag MAV7450AWW WASHER, ATLANTIS
Maytag MAV7501EWW WASHER, ATLANTIS
Maytag MAV7504EWW WASHER, ATLANTIS
Maytag MAV7550AWQ WASHER, ATLANTIS
Maytag MAV7550AWW WASHER, ATLANTIS
Maytag MAV7551AWQ WASHER, ATLANTIS
Maytag MAV7551AWW WASHER, ATLANTIS
Maytag MAV7557EWQ WASHER, ATLANTIS
Maytag MAV7557EWW WASHER, ATLANTIS
Maytag MAV7580EWQ WASHER, ATLANTIS
Maytag MAV7580EWW WASHER, ATLANTIS
Admiral MAV7600ACQ WASHER-TOP LOADING
Admiral MAV7600AGW WASHER-TOP LOADING
Maytag MAV7600AWQ WASHER, ATLANTIS
Maytag MAV7600AWW WASHER, ATLANTIS
Admiral MAV7600BGW WASHER-TOP LOADING
Admiral MAV7600CGW WASHER-TOP LOADING
Maytag MAV7650AWQ WASHER, ATLANTIS
Maytag MAV7650AWW WASHER, ATLANTIS
Maytag MAV7657EWQ WASHER, ATLANTIS
Maytag MAV7657EWW WASHER, ATLANTIS
Maytag MAV7700AWQ WASHER, ATLANTIS
Maytag MAV7700AWW WASHER, ATLANTIS
Admiral MAV7750AGW WASHER-TOP LOADING
Admiral MAV7750BGW WASHER-TOP LOADING
Admiral MAV7750CGW WASHER-TOP LOADING
Maytag MAV7757AWQ WASHER, ATLANTIS
Maytag MAV7757AWW WASHER, ATLANTIS
Maytag MAV8000AWQ WASHER, ATLANTIS
Maytag MAV8000AWW WASHER, ATLANTIS
Maytag MAV8057AWQ WASHER, ATLANTIS
Maytag MAV8057AWW WASHER, ATLANTIS
Maytag MAV8260AWQ WASHER, ATLANTIS
Maytag MAV8260AWW WASHER, ATLANTIS
Maytag MAV8500AWQ WASHER, ATLANTIS
Maytag MAV8500AWW WASHER, ATLANTIS
Maytag MAV8551AWQ WASHER, ATLANTIS
Maytag MAV8551AWW WASHER, ATLANTIS
Maytag MAV8557AWQ WASHER, ATLANTIS
Maytag MAV8557AWW WASHER, ATLANTIS
Maytag MAV8600AWQ WASHER, ATLANTIS
Maytag MAV8600AWW WASHER, ATLANTIS
Maytag MAV8601AWQ WASHER, ATLANTIS
Maytag MAV8601AWW WASHER, ATLANTIS
Maytag MAV8757AWQ WASHER, ATLANTIS
Maytag MAV8757AWW WASHER, ATLANTIS
Maytag MAV9501EWQ WASHER, ATLANTIS
Maytag MAV9501EWW WASHER, ATLANTIS
Maytag MAV9504EWQ WASHER, ATLANTIS
Maytag MAV9504EWW WASHER, ATLANTIS
Maytag MAV9557EWQ WASHER, ATLANTIS
Maytag MAV9557EWW WASHER, ATLANTIS
Maytag MAV9600EWQ WASHER, ATLANTIS
Maytag MAV9600EWW WASHER, ATLANTIS
Maytag MAV9657EWQ WASHER, ATLANTIS
Maytag MAV9657EWW WASHER, ATLANTIS
Maytag MAV9750AGW WASHER, ATLANTIS
Maytag MAV9750AWQ WASHER, ATLANTIS
Maytag MAV9750AWW WASHER, ATLANTIS
Maytag MAVT236AWW WASHER-TOP LOADING
Maytag MAVT346AWW WASHER-TOP LOADING
Maytag MAVT446AWW WASHER-TOP LOADING
Maytag MAVT546EWW WASHER-TOP LOADING
Maytag MAVT634AWW WASHER, ATLANTIS
Maytag MAVT734EWW WASHER, ATLANTIS
Maytag MAVT754EWW WASHER, ATLANTIS
Maytag MAVT834AWQ WASHER, ATLANTIS
Maytag MAVT834AWW WASHER, ATLANTIS
Whirlpool MB1110SLQ MICROWAVE OVEN 1.1 CUBIC FOOT
Admiral MB1927PEHB REF - MAYTAG INT'L BOT MOUNT
Admiral MB1927PEHW REF - MAYTAG INT'L BOT MOUNT
Admiral MB2216PUAW REF - BOTTOM MOUNTS
Maytag MB2216PUAW11 REFRIGERATOR
Maytag MB2216PUAW2 REFRIGERATOR
Admiral MB2227PEHB REF - MAYTAG INT'L BOT MOUNT
Admiral MB2227PEHW REF - MAYTAG INT'L BOT MOUNT
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
Maytag Atlantis only spins on high speed davidsg99 Washer Repair 2 06-02-2015 07:41 AM
Maytag Atlantis Washer Agitates but not spins GaryRGaal Washer Repair 1 07-01-2011 03:54 PM
Maytag Atlantis won't drain but spins jodyaz Washer Repair 0 08-21-2010 08:21 AM
Maytag Atlantis washer spins but doesn't drain water ramchaza Washer Repair 3 03-30-2010 10:40 AM
