Washer quit after filling up no spin. Drained water out. checked drain nothing clogging the impeller.
While pump loose tried to start in a spin cycle nothing. Turned the shaft by hand and it starts up. Will do that every time. I shut down turn on nothing turn shaft and it starts. I looked at coupling it looks ok, change start cap cause it's cheap didn't fix, hummimg is a little louder. Still turn shaft and it starts.
I can turn the motor with power off and see that the shaft turns, coupling and transmission shaft turns.
Am I looking at a motor replacement. Thanks for any help:
