Discuss
washer
 in
Washer Repair
Frigidaire front load washer has started leaving black marks on clothes in the pattern of the drum holes. Has also
Appliance Repair Forum > Appliance Repair Help > Washer Repair » washer
  #1 (permalink)
Old 11-01-2009, 09:29 AM
mycows mycows is offline
Junior Member
mycows is on a distinguished road
Default washer
Model Number: GLTF1240AS0   Brand: Frigidaire   Age: 5 - 10 years
Frigidaire front load washer has started leaving black marks on clothes in the pattern of the drum holes. Has also started making a load noise in spin cycle when it used to be quiet. Drum and rubber seal at the front are clean
Related Models
Frigidaire GLTF1240AS0 Frtld Washer - Frig Gallery
Frigidaire GLTF1570ES0 Frigidaire/washer
Frigidaire GLTF1570ES1 Frigidaire/washer
Frigidaire GLTF1570FS0 Frigidaire/washer
Frigidaire GLTF1670AS0 Frtld Wshr - Frigidaire Gal
Frigidaire GLTF1670AS1 Frigidaire/washer
Frigidaire GLTF2070CS0 Frigidaire/washer
Frigidaire GLTF2070DS0 Frigidaire/washer
Frigidaire GLTF2940EE0 Frigidaire/washer
Frigidaire GLTF2940ES0 Frigidaire/washer
Frigidaire GLTF2940ES1 Frigidaire/washer
Frigidaire GLTF2940ES2 Frigidaire/washer
Frigidaire GLTF2940ES3 Frigidaire/washer
Frigidaire GLTF2940FE0 Frigidaire/washer
Frigidaire GLTF2940FS0 Frigidaire/washer
Frigidaire GLTF530DS0 Frigidaire/washer
Frigidaire GLTF530DS1 Frigidaire/washer
Frigidaire GLTR1670AS0 Frtld Wshr - Frigidaire Gallery
Frigidaire GLTR1670AS1 Frigidaire/washer
Whirlpool GLWA6900W0
Whirlpool GLWA6900W1
Whirlpool GLWA6900W2
Frigidaire GLWS1233AQ1 Washer - Frig Gallery
Frigidaire GLWS1233AQ2 Frigidaire/washer
Frigidaire GLWS1233AS0 Washer - Frigidaire Gallery
Frigidaire GLWS1233AS1 Washer - Gallery
Frigidaire GLWS1233AS2 Frigidaire/washer
Frigidaire GLWS1233AS3 Frigidaire/washer
Frigidaire GLWS1339CC0 Frigidaire/washer
Frigidaire GLWS1339CS0 Frigidaire/washer
Frigidaire GLWS1339CS1 Frigidaire/washer
Frigidaire GLWS1339EC0 Frigidaire/washer
Frigidaire GLWS1339EC1 Frigidaire/washer
Frigidaire GLWS1339ES0 Frigidaire/washer
Frigidaire GLWS1339ES1 Frigidaire/washer
Frigidaire GLWS1349AS0 Washer - Frigidaire Gallery
Frigidaire GLWS1349AS1 Washer - Frig Gallery
Frigidaire GLWS1649AS0 Washer - Frig Gallery
Frigidaire GLWS1649AS1 Washer - Frig Gallery
Frigidaire GLWS1649AS2 Frigidaire/washer
Frigidaire GLWS1649AS4 Frigidaire/washer
Frigidaire GLWS1749AS0 Washer - Frigidaire Gallery
Frigidaire GLWS1749AS2 Washer - Frig Gallery
Frigidaire GLWS1749AS4 Frigidaire/washer
Frigidaire GLWS1749AS5 Frigidaire/washer
Frigidaire GLWS1939AS0 Frigidaire/washer
Frigidaire GLWS1939AS1 Frigidaire/washer
Frigidaire GLWS1979AS0 Washer - Frigidaire Gallery
Frigidaire GLWS1979AS2 Washer - Frig Gallery
Frigidaire GLWS1979AS3 Frigidaire/washer
Frigidaire GLWY1343AS0 Frigidaire/washer
Frigidaire GLWY1343AS1 Frigidaire/washer
Whirlpool GLXA6900W0
Whirlpool GLXA6900W1
Whirlpool GLXA6900W2
Whirlpool GLXA6900W3
Gaggenau GM104-710
Gaggenau GM104-714
International GM1110PRW Range - F/s Std Gas
Gaggenau GM215-721
Gaggenau GM215-760
Gaggenau GM215-761
Gaggenau GM286-710
Gaggenau GM286-720
Gaggenau GM286-760
Gaggenau GM288-710
Gaggenau GM288-714
International GM3110MPAW Range - F/s Std Gas
International GM3110MXAW Range - F/s Std Gas
International GM3110PRAM Range - F/s Std Gas
International GM3110PRWM Range - F/s Std Gas
International GM31113WAM Range - F/s Std Gas
International GM31113WAV Range - F/s Std Gas
International GM3111GXAW Range - F/s Std Gas
International GM3111SXAW Range - F/s Std Gas
International GM31211XAW Range - F/s Std Gas
International GM3167WUA Range - F/s Std Gas
International GM3167WUV Range - F/s Std Gas
International GM3210MXAW Range - F/s Cont Clean Gas
International GM3211GXAA Range - F/s Cont Clean Gas
International GM3211GXAW Range - F/s Cont Clean Gas
International GM3211SXAA Range - F/s Cont Clean Gas
International GM3211SXAW Range - F/s Cont Clean Gas
International GM3216WRWM Range - F/s Cont Clean Gas
International GM32211XAW Range - F/s Cont Clean Gas
International GM3267WUAM Range - F/s Cont Clean Gas
International GM3267WUWM Range - F/s Cont Clean Gas
International GM3267XUA Range - F/s Cont Clean Gas
International GM3267XUAM Range - F/s Cont Clean Gas
International GM3267XUW Range - F/s Cont Clean Gas
International GM3267XUWM Range - F/s Cont Clean Gas
Gaggenau GM335-760
Maytag GM3468XUW-X Range - S/c F/s Gas
Maytag GM3468XUWX Range - S/c F/s Gas
International GM3510PRW Range - F/s Std Ele
International GM3531WUV Range - S/c F/s Ele
International GM3531WUW Range - S/c F/s Ele
International GM3631XUA Range - F/s Std Ele
International GM3631XUW Range - F/s Std Ele
International GM3862XUW Range - S/c F/s Ele
International GM3868XUA Range - S/c F/s Ele
International GM3868XUW Range - S/c F/s Ele
Maytag GM4151WTA Range - F/s Std Gas
Maytag GM4151WTW Range - F/s Std Gas
Maytag GM4251WTA Range - F/s Cont Clean Gas
Maytag GM4251WTW Range - F/s Cont Clean Gas
Whirlpool GM8131XEB0
Whirlpool GM8131XEB1
Whirlpool GM8131XEQ0
Whirlpool GM8131XEQ1
Whirlpool GM8155XJB0
Whirlpool GM8155XJB1 Convection Microwave Oven
Whirlpool GM8155XJB2 Convection Microwave Oven
Whirlpool GM8155XJQ0
Whirlpool GM8155XJQ1 Convection Microwave Oven
Whirlpool GM8155XJQ2 Convection Microwave Oven
Whirlpool GM8155XJT0
Whirlpool GM8155XJT1 Convection Microwave Oven
Whirlpool GM8155XJT2 Convection Microwave Oven
Gaggenau GM915-710 UC/06 (FD 7710-7912)
  #2 (permalink)
Old 11-02-2009, 06:11 PM
sidfink43 sidfink43 is offline
Senior Expert
APP Volunteer
sidfink43 is on a distinguished road
Default
Take off the back and listen to see if the noise is coming from the rear bearing, which is very likely.
In that case you need to replace the entire back of the tub, which for most folks is too much money to put into the machine. Here is the part.
Part number: AP2578105
__________________
  #3 (permalink)
Old 11-03-2009, 06:44 AM
Junior Member
Default washer
thanks for the info. unfortunately I'm disabled and moving the washer not to mention taking it apart are not options. Any clue as to why the black marks on the clothes?
  #4 (permalink)
Old 11-03-2009, 08:46 AM
Senior Expert
APP Volunteer
Default
Sorry to hear about your disability.
The black marks are somewhat of a mystery, sounds like something got into the cabinet, but you would have to take the cabinet apart to see what it is and if it can be cleaned off.
Given that the bearing is probably going you may want to think about a new or late model used machine. I would get a basic top loader because it will do a good job for you and should not require any major repairs.
__________________
  #5 (permalink)
Old 11-03-2009, 10:36 AM
Junior Member
Thumbs up
THANKS FOR THE HELP. Looks like hat might be my only option.
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
