Discuss
Older Kenmore Front Loader motor trouble
 in
Washer Repair
Hello, Love this washer...sure hope to keep it going. The motor does not turn the drum. The motor moves slowly/not
Appliance Repair Forum > Appliance Repair Help > Washer Repair » Older Kenmore Front Loader motor trouble
  #1 (permalink)
Old 06-26-2016, 04:24 PM
Junior Member
canyn is on a distinguished road
Default Older Kenmore Front Loader motor trouble
Model Number: 417.84988800   Brand: Kenmore   Age: More than 10 years
Hello,
The motor does not turn the drum. The motor moves slowly/not smoothly with the belt off in the same fashion in both CW and CCW directions in accordance with the timer 'slow' mode positions. In 'spin' mode, the motor moves the same way..slowly and somewhat erratically (jerky). 'Slowly' meaning not even a 1/2 revolution in five seconds. After about 10 seconds of trying to turn, the motor shuts off. I presume that to be an over-current protection situation.
I have a spare motor control board from a previous 'THAT didn't fix it!' event. I swapped that in. No change.
Both motor brushes look fine. A manual twist to the motor and the bearings/commutator are smooth and quiet.
An earlier repair to this motor involved the speed transducer/tachgenerator. The magnet had come loose from the motor shaft, the symptom being the motor ran too fast during a 'slow' (wash) function. I JB'd the magnet in place. It's been fine for years. The magnet is still in place, a voltage is generated on the tachgen output wires with a handspin of the motor.
Resistance between commutator segments is around .4ohms. At 180 on the commutator it's about 1.4ohms. No segments look any different resistance-wise one from another. While THAT part is good, I did expect higher readings than I got. Certainly I'm no motor guru. I don't know if such low readings are OK or not.
I'm hoping this is a fairly common DC motor/front loader issue that someone has seen plenty of and the answer is a 'fer sure. I am not looking forward to spending a months income on a new washing machine!
Thanks for the opportunity to ask!
**edit** Don't see the model number I put in showing..a duplicate won't hurt.
Model: 417.84988800
Related Models
Kenmore 41715644 OUTDOOR GRILL
Kenmore 41724182300 WASHER
Kenmore 41724182301 WASHER
Kenmore 41727182700 WASHER
Kenmore 41727182701 WASHER
Kenmore 41727182702 WASHER
Kenmore 41727182703 WASHER
Kenmore 41727182704 WASHER
Kenmore 41729022890 FREESTANDING WASHER
Kenmore 41729042990 FRONTLOAD WASHER
Kenmore 41729042991 KENMORE WASHER
Kenmore 41729042992 FRONT LOAD WASHER
Kenmore 41729052990 KENMORE WASHER
Kenmore 41729052991 WASHER
Frigidaire 41739012890 Frg(v0) / Washer
Kenmore 41739012890 STACK WASHER
Kenmore 41739012891 WASHER
Frigidaire 41739012891 WASHER
Frigidaire 41739022890 Frg(v0) / Washer
Kenmore 41739022891 WASHER
Frigidaire 41739022891 Frg/washer
Kenmore 41740032990 WASHER
Kenmore 41740042990 WASHER
Kenmore 41740052990 WASHER
Kenmore 41740142000 WASHER
Kenmore 41740412700 WASHER
Kenmore 41740412701 WASHER
Kenmore 41740412702 SEARS/FRONT LOAD WASHER -0582
Kenmore 41740412703 WASHER
Kenmore 41741042000 WASHER
Kenmore 41741052000 FRONTLOAD WASHER
Kenmore 41741100000 WASHER
Kenmore 41741101000 WASHER
Kenmore 41741102000 WASHER
Kenmore 41741142000 RESIDENTIAL WASHER
Kenmore 41742042100 WASHER
Kenmore 41742052100 WASHER
Kenmore 41742142100 WASHER
Kenmore 41743042200 SEARS/FRONTLOAD WASHER
Kenmore 41743042300 WASHER
Kenmore 41743052200 SEARS/FRONTLOAD WASHER
Kenmore 41743142200 SEARS/FRONTLOAD WASHER
Kenmore 41743142300 WASHER
Kenmore 41744042400 WASHER
Kenmore 41744052400 WASHER
Kenmore 41744052401 WASHER
Kenmore 41744052500 WASHER
Kenmore 41744072300 WASHER
Kenmore 41744082400 WASHER
Kenmore 41744082500 WASHER
Kenmore 41744092500 WASHER
Kenmore 41744102300 WASHER
Kenmore 41744102301 WASHER
Kenmore 41744130000 WASHER
Kenmore 41744131000 WASHER
Kenmore 41744132000 WASHER
Kenmore 41744142400 WASHER
Kenmore 41744152400 WASHER
Kenmore 41744152401 WASHER
Kenmore 41744152500 WASHER
Kenmore 41744252500 WASHER
Kenmore 41744252501 WASHER
Kenmore 41747102700 WASHER
Kenmore 41747102701 WASHER
Kenmore 41748102700 WASHER
Kenmore 41748102701 WASHER
Kenmore 41748106700 WASHER
Kenmore 41748112700 WASHER
Kenmore 41748112701 WASHER
Kenmore 41748116700 WASHER
Frigidaire 41749012890 Frg(v0) / Dryer
Frigidaire 41749022890 Frg(v0) / Dryer
Frigidaire 41759012890 Frg(v0) / Dryer
Kenmore 41759012890 GAS DRYER
Frigidaire 41759022890 Frg(v0) / Dryer
Kenmore 41759022890 GAS DRYER
Kenmore 41764182300 ELECTRIC DRYER
Kenmore 41769042990 KENMORE DRYER
Kenmore 41769042991 DRYER
Kenmore 41769052990 DRYER
Kenmore 41769052991 ELECTRIC DRYER
Kenmore 41774182300 GAS DRYER
Kenmore 41774182301 GAS DRYER
Kenmore 41779042990 DRYER
Kenmore 41779042991 DRYER
Kenmore 41779052990 DRYER
Kenmore 41779052991 DRYER
Kenmore 41780032990 DRYER
Kenmore 41780042990 DRYER
Kenmore 41780042991 DRYER
Kenmore 41780052990 DRYER
Kenmore 41780052991 DRYER
Kenmore 41780142000 DRYER
Kenmore 41780412700 DRYER
Kenmore 41781042000 DRYER
Kenmore 41781042001 DRYER
Kenmore 41781052000 ELECTRIC DRYER
Kenmore 41781052001 DRYER
Kenmore 41781100000 DRYER
Kenmore 41781101000 DRYER
Kenmore 41781102000 DRYER
Kenmore 41781142000 DRYER
Kenmore 41781142001 DRYER
Kenmore 41782042100 DRYER
Kenmore 41782042101 DRYER
Kenmore 41782042102 SEARS/DRYER
Kenmore 41782052100 DRYER
Kenmore 41782052101 DRYER
Kenmore 41782052102 DRYER
Kenmore 41782052103 SEARS/ELECTRIC DRYER
Kenmore 41782142100 DRYER
Kenmore 41782142101 DRYER
Kenmore 41782142102 SEARS/ELECTRIC DRYER
Kenmore 41783042200 SEARS/DRYER
Kenmore 41783042201 SEARS/ELECTRIC DRYER
Kenmore 41783042300 DRYER
Kenmore 41783052200 SEARS/DRYER
Kenmore 41783052201 SEARS/DRYER
Kenmore 41783142200 SEARS/DRYER
Kenmore 41783142201 SEARS/ELECTRIC DRYER
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
GE Front Loader-motor runs but not agitating or spinning lilkel37 Washer Repair 13 05-12-2012 03:13 PM
Maytag front loader control panel or motor astephens99 Washer Repair 1 03-18-2011 01:59 PM
Older Kenmore Leaking in front Miculiz Washer Repair 5 03-21-2010 02:46 PM
Kenmore front loader batesville Washer Repair 3 02-15-2010 06:19 AM
kenmore front loader fell onto front while moving. ohhhden Washer Repair 1 01-26-2010 07:22 PM
