Discuss
maytag neptune leaks water
 in
Washer Repair
Hi, I had the washer/dryer stackable unit stored for about a year. when i used it last week, it leaked
Appliance Repair Forum > Appliance Repair Help > Washer Repair » maytag neptune leaks water
  #1 (permalink)
Old 10-31-2009, 08:52 PM
Junior Member
oscarwylie is on a distinguished road
Default maytag neptune leaks water
Brand: Maytag   Age: 1 - 5 years
I had the washer/dryer stackable unit stored for about a year. when i used it last week, it leaked on the bottom (over a gallon of water). I open the back and noticed that when i opened the cold water fawcett, water would fill up the washer even though the control was off/unplugged. the hot water did not do that. when i tested it, the washer would wash but it would be full of water and the door was opened. i don't think that the cold water should be filling up so i am thinking maybe the inlet valve may be stuck since i have not used the washer. please help . thanks frank
Ads By Google
  #2 (permalink)
Old 11-01-2009, 06:33 AM
Senior Expert
APP Volunteer
denman is just really nice
Default
A Model Number may help others help you
If you stored it in a location that could freeze then you probably have some cracked parts
Sounds like the water valves need replacing
Do not understand this, Neptune stacked units usually have a front load washer so I cannot see how it could run full of water with the door open.
__________________
  #3 (permalink)
Old 11-01-2009, 06:51 AM
Junior Member
Default thanks denman
hi, thank you for the quick reply!
The unit was stored inside the house above freezing point.
I am sorry, I should have been clearer. When I tested the washer, I ran it with some light clothing on just cold water. it seemed to be operating okay. towards the end of the cycle (i am not sure if it was before or after the spin), I came into the laundry room and saw the washer stopped with the door wide open with water overflowing. I shut off the cold water, closed the door and turned to the spin cycle and the washer completed the wash. Should I call a repairman? I took the inlet valve out and the cold water valve seemed to be "stuck". Could this also be a control problem (computer control board) or do you think that by changing the inlet valves, this problem would be resolved? Any tips on how to best change the valve? Thanks again, Frank
  #4 (permalink)
Old 11-01-2009, 07:03 AM
Senior Expert
APP Volunteer
Default
Cannot say, it depends on your DIY skill.
Perhaps the below manual will help you decide.
Since it stayed open with the unit unplugged I would say it is just a valve problem.
Not sure why the door opened.
See the below manual
http://www.servicematters.com/maytag...s/16009127.pdf
__________________
  #5 (permalink)
Old 11-01-2009, 07:32 AM
Junior Member
Default thanks Denman
Hi I saw the troubleshooting guide/manual and I will order the parts and attempt to change it myself. I searched for maytag water inlet valve in applianceparts and they did not have it. did i do something wrong? I dont have the model number at hand. I'll try again. thanks and i'll post it here on how i did. have a great day, Frank.
  #6 (permalink)
Old 11-01-2009, 08:26 AM
Senior Expert
APP Volunteer
Default
You will need the model number from your machine to ensure you get the correct part.
Good luck!!!
Just take your time.
Mark any wires you take off so you know where they go when re-assembling.
__________________
  #7 (permalink)
Old 11-01-2009, 08:31 AM
Junior Member
Default Many Thanks Denman
You have been very helpful!! Great site.
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
Maytag Neptune Washer no hot water harperhomewa Washer Repair 2 03-29-2011 01:29 PM
maytag neptune wont agitate after it take little water mani Washer Repair 2 08-28-2009 03:55 PM
Maytag Neptune water issue mpdsal Washer Repair 2 03-29-2009 09:04 PM
Maytag Neptune won't extract water completely letsal Dishwasher Repair 3 05-19-2008 12:23 PM
maytag washer neptune only put out warm or hot water no cold misterfixall Washer Repair 0 11-22-2007 03:16 PM
