Hello,
I got a Whirlpool Cambrio Platinum used (WTW8200YW0).- it was actually from my parents, who used it for a month before storing it for about 18 months. Anywho- I noticed that there is a leak on the front left side and from some extensive investigation, determined that the water is actually coming from water splashing off the tub when filling by the detergent. When I look down into the washer I can clearly see that the tub is off center- leaning more toward the back right. The washer itself is level.
I am about to order a new suspension rod kit but whated to see if anyone experenced a similar issue before I do so.
Thanks!
