My GE washer has issues spinning sometimes, I have checked the lid switch and determined that it was an issue, so at this point, until I get the new one, I have it jumped out with a wire nut, so lid up or down it still will normally spin, ok, here is where it gets a little weird, I can set it to do any wash cycle, fills, agitates, etc...I come back later and it's off, no lights, but if I lift the lid, I can determine the spin cycle didn't complete, so I turn the selector to spin, hit the power button, the pump comes on to discharge water, but the only way I can get it to start spinning is undo the lid switch wires and reconnect them, then it spins and finishes, any ideas?
