My GE front load washer fills up with water, in all the cycles. than it drains the water, than it stops. i push the start button again and the cycle repeats, fills with water than it drains it. doesnt agitate. initial the drum turns to check the load balance.
i check the front switch and the the door lock and both are good. i put the washer in the drain and spin cycle and the cycle works fine.
any help is greatly appreciated.
thank you in advance...
