Hi, I have a Whirlpool Cabrio Washer & Dryer. The washer model number is WTW6300SW1. Every time it spins at the end of wash cycle, we get the off balance code (UL) on the display and it quits spinning. We constantly have to adjust the clothes in the tub to try and make it work, but it did not do this previously--it only started after we had it in storage for about a year then moved it and began using it again. When it spins, it seems to go ok for a while, then starts bouncing up and down and that's when it gets the UL and stops. I don't recall it bouncing before--is there some part missing that is not holding it down or something?
