Is there a special tool or trick to get the gear assembly or washplate to not turn while I am trying to get the pulley nut off. The pulley worked its way off so that the teeth are no longer engaging and I am trying to get the nut to break free, I've doused it in a break free lubricant to see if that will help but so far no luck.
