maestro1928
#1 Posted : Thursday, February 11, 2016 6:09:51 AM(UTC)
maestro1928
Washer will only spin in one direction and stop. When i turn the basket by hand it will spin in one direction and when I try to go the opposite it will stop
Joe / APP Team
#2 Posted : Thursday, February 11, 2016 11:44:10 AM(UTC)
Joe / APP Team
Maestro, Sounds like something is "stuck" between the tubs or between the belt and tub pulley. it could also be a "scored" or seized tub bearing, you didn't mention any noises of clicking sounds, you should be able to manually turn the tub in both directions. You may want to conduct the service test mode and review the error codes(see the attachment) it may help point you in the right direction.
File Attachment(s):
Binder1.pdf (56kb) downloaded 2 time(s).
LG front load washer part id (Washer Repair)
by Cgreen0117 3/24/2024 10:49:09 AM(UTC)
Frigidaire Front Load Washer only spins fast (Washer Repair)
by Guest 2/6/2024 12:15:55 PM(UTC)
Whirlpool Duet front load washer model WFW8300SW02 (Washer Repair)
by Guest 12/4/2023 8:39:10 AM(UTC)
Whirlpool front load washer WFW9620HBK0 problems (Washer Repair)
by ctbirkett 8/28/2023 4:28:27 AM(UTC)
Maytag Maxima front load washer hangs on spin cycle (Washer Repair)
by jcross100 8/6/2023 11:56:11 AM(UTC)
Lr code on my Maytag Neptune Front Load Washer (Washer Repair)
by Guest 11/19/2022 9:53:55 AM(UTC)
LTF2940FE0 FRIGIDAIRE FRONT LOAD WASHER (Washer Repair)
by Guest 9/8/2022 9:06:55 PM(UTC)
LG front load washer water leak (Washer Repair)
by Guest 7/23/2022 11:17:44 AM(UTC)
fRIDGIDAIRE AFFINITY FRONT LOAD WASHER WILL NOT STAY IN LOCK MODE (Washer Repair)
by Guest 2/21/2022 3:21:13 PM(UTC)
Maytag Neptune Front Load Washer “do” code (Washer Repair)
by Guest 12/25/2021 2:22:33 PM(UTC)
Samsung front load washer rotor cover hitting (Washer Repair)
by Kickerjb44 12/19/2021 3:31:57 PM(UTC)
Samsung Front Load Washer Gets Stuck at 1 Minute (Washer Repair)
by Radar314 11/12/2021 5:45:08 AM(UTC)
maytag 2000 front load washer (Washer Repair)
by crazyeyebrad 10/30/2021 7:34:44 AM(UTC)
WF56H9100AG/A2 Samsung Front Load Washer Displays 4e / LE error code (Washer Repair)
by dcgtechnologies 10/1/2021 9:38:54 PM(UTC)
LG front load washer making grinding noise (Refrigerator & Freezer Repair)
by Guest 9/18/2021 8:57:25 AM(UTC)
