jefffox
#1 Posted : Wednesday, January 13, 2016 12:36:13 PM(UTC)
jefffox
no flashing led
correct voltages at all pins
no error codes on field service mode checks
MODE SHIFTER COIL TEST SHOWS NO CONTINUITY
thanks
jeff
sidfink43
#2 Posted : Thursday, January 14, 2016 4:19:14 PM(UTC)
sidfink43
If you are not getting error codes and you have done the reset process it is the motor/inverter that is probably the problem. If you buy the part from this site and it does not fix the problem you can return it. But it is an expensive repair and you might want to just replace the machine with a nice no frills, no electronics top loader.
