Discuss
Whirlpool Washer not spinning
 in
Washer Repair
After doing 2 loads of laundry yesterday, the washer stopped spinning. It cycled all the way through and completed the
Appliance Repair Forum > Appliance Repair Help > Washer Repair » Whirlpool Washer not spinning
  #1 (permalink)
Old 10-30-2009, 09:05 PM
Junior Member
A1adventures is on a distinguished road
Default Whirlpool Washer not spinning
Model Number: LSN2000PW   Brand: Whirlpool   Age: 1 - 5 years
After doing 2 loads of laundry yesterday, the washer stopped spinning. It cycled all the way through and completed the fill for rinse, but did not spin. Advancing the switch, the pump functions and empties the water.
A couple of things. 1) I have tried jumping the lid switch with the same effect as having the lid closed - a humming noise (assuming the motor is trying to turn the basket but cannot generate enough force to make it spin). 2) I have replaced the motor couple as the last was significantly worn. Still not spinning. 3) I took off the gear assembly and checked both the clutch and break. There appears to be plenty of break pad left, I can manipulate the break by hand with a counter clockwise turn and the spring depresses as it should. 4) The clutch is in tact - do not know what signs of wear would look like besides the band being cracked or obviously worn (neither of which is the case). 5) Both the gear case (agitator shaft) and motor spin freely when detached from the basket.
I am out of ideas - unless it is a break/clutch issue that I do not have experience enough to discern as I do not know what a properly functioning break/clutch set up looks like. Any help would be appreciated.
Thanks,
Blake
Ads By Google
Related Models
Whirlpool LSN2000PW0 Automatic Washer
Whirlpool LSN2000PW1 Automatic Washer
Whirlpool LSN2000PW2 Automatic Washer
Whirlpool LSN2000PW3 Automatic Washer
Whirlpool LSN2000PW4 Automatic Washer
Whirlpool LSN3000PG0 Automatic Washer
Whirlpool LSN3000PG1 Automatic Washer
Whirlpool LSN3000PG2 Automatic Washer
Whirlpool LSN3000PG3 Automatic Washer
Whirlpool LSN3000PG4 Automatic Washer
Whirlpool LSN3000PW0 Automatic Washer
Whirlpool LSN3000PW1 Automatic Washer
Whirlpool LSN3000PW2 Automatic Washer
Whirlpool LSN3000PW3 Automatic Washer
Whirlpool LSN3000PW4 Automatic Washer
Whirlpool LSN7233BN0
Whirlpool LSN7233BN1
Whirlpool LSN7233BQ0
Whirlpool LSN7233BQ1
Whirlpool LSN7233BW0
Whirlpool LSN7233BW1
Whirlpool LSN7233DQ0
Whirlpool LSN7233DW0
Whirlpool LSN8244AN0
Whirlpool LSN8244AQ0
Whirlpool LSN8244AW0
Whirlpool LSN8244BN0
Whirlpool LSN8244BQ0
Whirlpool LSN8244BW0
Whirlpool LSP6244AG0
Whirlpool LSP6244AN0
Whirlpool LSP6244AW0
Whirlpool LSP6244BG0
Whirlpool LSP6244BN0
Whirlpool LSP6244BW0
Whirlpool LSP8244BG0
Whirlpool LSP8244BG1
Whirlpool LSP8244BN0
Whirlpool LSP8244BN1
Whirlpool LSP8244BW0
Whirlpool LSP8244BW1
Whirlpool LSP8245AN0
Whirlpool LSP8245AW0
Whirlpool LSP8245BN0
Whirlpool LSP8245BW0
Whirlpool LSP9245BN0
Whirlpool LSP9245BN1
Whirlpool LSP9245BW0
Whirlpool LSP9245BW1
Whirlpool LSP9355AG0
Whirlpool LSP9355AN0
Whirlpool LSP9355AW0
Whirlpool LSP9355BN0
Whirlpool LSP9355BN1
Whirlpool LSP9355BW0
Whirlpool LSP9355BW1
Whirlpool LSQ7030KQ0
Whirlpool LSQ7030LQ0
Whirlpool LSQ7030LT0
Whirlpool LSQ7030MQ0 Automatic Washer
Whirlpool LSQ7533JQ0
Whirlpool LSQ7533JQ1
Whirlpool LSQ7533JT0
Whirlpool LSQ7533JT1
Whirlpool LSQ8000HQ0
Whirlpool LSQ8000JQ0
Whirlpool LSQ8000JQ1
Whirlpool LSQ8000LQ0
Whirlpool LSQ8000LQ1 Automatic Washer
Whirlpool LSQ8000LQ2 Automatic Washer
Whirlpool LSQ8000LQ3 Automatic Washer
Whirlpool LSQ8200HQ0
Whirlpool LSQ8200HZ0
Whirlpool LSQ8220HQ0
Whirlpool LSQ8243HQ0
Whirlpool LSQ8243HZ0
Whirlpool LSQ8500JQ0
Whirlpool LSQ8500JQ1
Whirlpool LSQ8500JQ2
Whirlpool LSQ8500JT0
Whirlpool LSQ8500JT1
Whirlpool LSQ8500JT2
Whirlpool LSQ8500LQ0 Automatic Washer
Whirlpool LSQ8510LQ0 Automatic Washer
Whirlpool LSQ8511KQ0
Whirlpool LSQ8511KT0
Whirlpool LSQ8512KQ0
Whirlpool LSQ8512KT0
Whirlpool LSQ8520JQ0
Whirlpool LSQ8520JQ1
Whirlpool LSQ8543JQ0
Whirlpool LSQ8543JQ1
Whirlpool LSQ8543JT0
Whirlpool LSQ8543JT1
Whirlpool LSQ8543JZ0
Whirlpool LSQ8543JZ1
Whirlpool LSQ9010KQ0
Whirlpool LSQ9010KT0
Whirlpool LSQ9010LG0
Whirlpool LSQ9010LG1 Automatic Washer
Whirlpool LSQ9010LG2 Automatic Washer
Whirlpool LSQ9010LG3 Automatic Washer
Whirlpool LSQ9010LQ0
Whirlpool LSQ9010LQ1 Automatic Washer
Whirlpool LSQ9010LQ2 Automatic Washer
Whirlpool LSQ9010LW0
Whirlpool LSQ9010LW1 Automatic Washer
Whirlpool LSQ9010LW2 Automatic Washer
Whirlpool LSQ9010LW3 Automatic Washer
Whirlpool LSQ9010PG0 Automatic Washer
Whirlpool LSQ9010PG1 Automatic Washer
Whirlpool LSQ9010PG2 Automatic Washer
Whirlpool LSQ9010PG3 Automatic Washer
Whirlpool LSQ9010PG5 Automatic Washer
Whirlpool LSQ9010PG6 Automatic Washer
Whirlpool LSQ9010PW0 Automatic Washer
Whirlpool LSQ9010PW1 Automatic Washer
Whirlpool LSQ9010PW2 Automatic Washer
Whirlpool LSQ9010PW3 Automatic Washer
Whirlpool LSQ9010PW5 Automatic Washer
  #2 (permalink)
Old 10-31-2009, 06:41 AM
Junior Member
BergerWasher is on a distinguished road
Default Same issue- different washer
I am having the same issue, but have a different make and model.
The washer stopped spinning. It cycled all the way through and completed the fill for rinse, but did not spin.
I have a Frigidaire AFT7000EE0 front load washer. We cleaned out the drain and found and remove about 3 coins. Reassembled and then tried another load.
The washer stopped spinning. It cycled all the way through and completed the fill for rinse, but did not spin. AGAIN.
Can someone suggest what I can do to troubleshoot OR what else I might need to do???
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
Whirlpool front loading washer spinning problems godp1301 Washer Repair 2 02-23-2010 06:24 AM
Whirlpool Washer slowly stopped spinning jphil Washer Repair 0 10-13-2009 09:39 AM
Whirlpool Washer Wobbles when spinning valboynton58 Washer Repair 1 08-08-2009 03:47 PM
whirlpool washer has trouble spinning ploose@omnek.com Washer Repair 1 03-06-2009 08:11 PM
Whirlpool Washer humming but not spinning hillaholic Washer Repair 1 10-31-2008 10:34 AM
