I put some clothes on to wash last night, only to go to the garage bout 30 minutes later to find a flood. After inspecting the washer, I found about a 6 inch crack in the bottom of the drum liner (tub). Any ideas on what I could do to patch the crack up?
Check your warranty. Often tubs have a longer warranty than one year.
Also a Model Number would help if you are going to need a replacement. |
THIS FORUM IS DEAD!!!!!!! |
