We set the timer to fill the machine with clothes and water to start the wash cycle. The machine did fill but then did not advance to start agitating or move into any cycle. Instead it started to make a buzzing noise, which lasted for about 30 seconds and then that kicked off the circuit breaker. The washer shares an outlet with the dryer which is still able to function after the breaker was reset, so it appears that the electricity going to the outlet is fine. After resetting the circuit breaker, we tried resetting the washer timer and the washer would not do anything except make a buzzing noise and it just kept retripping the circuit breaker. We had to manually drain the water from the machine because we couldn't even get it to do that. Any ideas what could be wrong with it? Thanks.
