We have a leak in the washing machine. I bought the kit (Whirlpool W10435302 Bearing) to repair the seals and bearings. I have followed the directions to remove most of the items on top and below. However I am stuck still unable to get to the middle of the machine. Last step I removed the tub nut with the spanner wrench and am still unable to pull out the tub. I pull out the screws from the plate that is still there, but no movement. I have attached pictures of the plate and items remaining. The shaft turns but other then that nothing else wants to budge. klm1421 attached the following image(s):
