Discuss
washer fills, drains while agitating, and refills multiple times during operation
 in
Washer Repair
I have a Whirlpool LA7800XP washer which fill normally, but when the unit starts to aggitate the drain pump starts
Appliance Repair Forum > Appliance Repair Help > Washer Repair » washer fills, drains while agitating, and refills multiple times during operation
  #1 (permalink)
Old 10-30-2009, 08:31 AM
Roger Trzebiatowski Roger Trzebiatowski is offline
Junior Member
Roger Trzebiatowski is on a distinguished road
Default washer fills, drains while agitating, and refills multiple times during operation
Model Number: LA7800XP   Brand: Whirlpool   Age: More than 10 years
I have a Whirlpool LA7800XP washer which fill normally, but when the unit starts to aggitate the drain pump starts to drain at the same time, when the water level gets low, it stops refills the continues and repeats the entire process. I inspected the timer controller assembly (660992) and discovered a burnt set of contacts inside. I placed an order with Applinacepartspros.com last night, but am wondering if there is anything additional which could cause this problem?
Related Models
Whirlpool LA7800XPW0
Whirlpool LA7800XPW1
Whirlpool LA7800XSW0
Whirlpool LA7800XSW1
Whirlpool LA7800XSW2
Whirlpool LA7800XTF0
Whirlpool LA7800XTF1
Whirlpool LA7800XTG0
Whirlpool LA7800XTG1
Whirlpool LA7800XTM0
Whirlpool LA7800XTM1
Whirlpool LA7800XTN0
Whirlpool LA7800XTN1
Whirlpool LA7800XTW0
Whirlpool LA7800XTW1
Whirlpool LA7801XTF0
Whirlpool LA7801XTG0
Whirlpool LA7801XTM0
Whirlpool LA7801XTN0
Whirlpool LA7801XTW0
Whirlpool LA7805XKW0
Whirlpool LA7805XKW1
Whirlpool LA7899XPW3
Whirlpool LA7900XPW1
Whirlpool LA7900XSW0
Whirlpool LA7900XSW1
Whirlpool LA7900XSW2
Whirlpool LA7900XTF0
Whirlpool LA7900XTG0
Whirlpool LA7900XTG1
Whirlpool LA7900XTM0
Whirlpool LA7900XTN0
Whirlpool LA7900XTN1
Whirlpool LA7900XTW0
Whirlpool LA7900XTW1
Whirlpool LA7980XSW0
Frigidaire LA800AXD1 Wwh(v2) / 27 " Washer
Frigidaire LA800AXD2 Wwh(v2) / 27 " Washer
Frigidaire LA800AXW1 Wwh(v1) / 27 " Washer
Frigidaire LA800AXW2 Wwh(v1) / 27 " Washer
Frigidaire LA800JXD4 Wwh(v1) / Washer
Frigidaire LA800JXD5 Wwh(v1) / Top Load Washer
Frigidaire LA800JXF4 Wwh(v2) / Washer
Frigidaire LA800JXH4 Wwh(v3) / Washer
Frigidaire LA800JXH5 Wwh(v2) / Top Load Washer
Frigidaire LA800JXV4 Wwh(v4) / Washer
Frigidaire LA800JXW4 Wwh(v5) / Washer
Frigidaire LA800JXW5 Wwh(v3) / Top Load Washer
Frigidaire LA800MXD1 Wwh(v9) / 27 " Washer
Frigidaire LA800MXD2 Wwh(v9) / 27 " Washer
Frigidaire LA800MXH1 Wwh(v8) / 27 " Washer
Frigidaire LA800MXH2 Wwh(v8) / 27 " Washer
Frigidaire LA800MXW1 Wwh(v7) / 27 " Washer
Frigidaire LA800MXW2 Wwh(v7) / 27 " Washer
Maytag LA806 Washer - Top Loading
Maytag LA806S Washer - Top Loading
Maytag LA810 Washer - Top Loading
Maytag LA8100 Washer - Top Loading
Whirlpool LA8100XWW0
Whirlpool LA8100XWW1
Maytag LA8120 Washer - Top Loading
Maytag LA8140 Washer - Top Loading
Maytag LA8200 Washer - Top Loading
Whirlpool LA8200XWW0
Whirlpool LA8200XWW1
Maytag LA8210 Washer - Top Loading
Maytag LA8240 Washer - Top Loading
Maytag LA8340 Washer - Top Loading
Amana LA83830.A Mwave - Family Size (60 Hz)
Whirlpool LA8400XWF0
Whirlpool LA8400XWF1
Whirlpool LA8400XWG0
Whirlpool LA8400XWG1
Whirlpool LA8400XWM0
Whirlpool LA8400XWM1
Whirlpool LA8400XWN0
Whirlpool LA8400XWN1
Whirlpool LA8400XWW0
Whirlpool LA8400XWW1
Maytag LA8420 Washer - Top Loading
Maytag LA8440 Washer - Top Loading
Maytag LA8500 Washer - Top Loading
Maytag LA8520 Washer - Top Loading
Whirlpool LA8580XWF0
Whirlpool LA8580XWF1
Whirlpool LA8580XWF2
Whirlpool LA8580XWG0
Whirlpool LA8580XWG1
Whirlpool LA8580XWG2
Whirlpool LA8580XWM0
Whirlpool LA8580XWM1
Whirlpool LA8580XWM2
Whirlpool LA8580XWN0
Whirlpool LA8580XWN1
Whirlpool LA8580XWN2
Whirlpool LA8580XWW0
Whirlpool LA8580XWW1
Whirlpool LA8580XWW2
Maytag LA8600 Washer - Top Loading
Maytag LA8640 Washer - Top Loading
Maytag LA8650 Washer - Top Loading
Maytag LA8700 Washer - Top Loading
Maytag LA8740 Washer - Top Loading
Maytag LA8800 Washer - Top Loading
Whirlpool LA8800XSW0
Whirlpool LA8800XSW1
Whirlpool LA8800XSW2
Whirlpool LA8800XTF0
Whirlpool LA8800XTF1
Whirlpool LA8800XTG0
Whirlpool LA8800XTG1
Whirlpool LA8800XTM0
Whirlpool LA8800XTM1
Whirlpool LA8800XTN0
Whirlpool LA8800XTN1
Whirlpool LA8800XTW0
Whirlpool LA8800XTW1
Maytag LA882 Washer - Top Loading
Maytag LA8820 Washer - Top Loading
Maytag LA882T Washer - Top Loading
  #2 (permalink)
Old 10-31-2009, 06:56 PM
sidfink43 sidfink43 is offline
Senior Expert
APP Volunteer
sidfink43 is on a distinguished road
Default
That seems like the likely problem, particularly with the burnt contacts. Let us know how it works out.
__________________
  #3 (permalink)
Old 11-03-2009, 09:27 AM
Junior Member
Default
I received the part this morning and installed it, but the draining while aggitating is still occurring. For some reason the drain starts as soon as aggittation begins. It aggitates until the water level drops, then stops, refills, continues aggitating again while draining, and keeps repeating this cycle until the time period has run out.
Obviously this uses 10 to 20 times more water then need be.
  #4 (permalink)
Old 11-03-2009, 10:32 AM
applianceman applianceman is offline
Senior Member
applianceman is on a distinguished road
Default
I don’t know a whole lot about this washer but your water pump has a lever that when tripped it pumps out. This lever is connected to what they call a wig-wag. The wig-wag is just two arms that push and pull continuously then when it is time to change cycles the solenoids on top will engage allowing the arms to trip the water pump.
If the lever on the water pump isn’t getting tripped the wig-wag may be your problem. If the lever is getting tripped but you are still having this problem the water pump may be your problem. Hope this helps!
You may be able to manually tripp the lever on the pump to see if the water stops pumping out.
Clothes Washer Repair Guide
  #5 (permalink)
Old 11-04-2009, 11:46 PM
Junior Member
Default
Applianceman, I think you may be onto something here. I checked the wigwag solenoids, they both read roughly 0.5 ohms, so should be intact. I did order a replacement anyways, How do the arms work, are they moved forward and backward by the pump or what? the solenoid plungers were somewhat sticky from dust and grim, I cleaned them, sprayed a little WD-40 on them, reassembled. but the problem still exists. I am guessing the arms are supposed to move forward and backward by the drive unit?
Is there supposed to be certain positions which turn the pump on and off?
could some debris internally cause it to stay open or engaged?
Thank you for your assistance so far.
  #6 (permalink)
Old 11-05-2009, 01:01 AM
Junior Member
Default
I dropped the pump off, took a look inside, found a rubber flat plug wedged crossways on the inlet portion of the pump. But this would not have caused the issues. The rods however which moves forward and backward from the wigwag to the pump actuator level on the pump seem to be rather stiff. I am guessing something between the drive mechanism which moves that arm forward and backward needs lubrication or is damaged. I will take a closer look at it in the morning.
  #7 (permalink)
Old 11-05-2009, 03:15 AM
richappy richappy is offline
Senior Expert
APP Volunteer
richappy is a glorious beacon of light
Default
If you take out the stuff jaming the pump, this will solve your problem.
__________________
  #8 (permalink)
Old 11-05-2009, 08:23 AM
Junior Member
Default
No the rubber washer was in the inlet pipe to the pump. THe problem is the pump drains while aggitating, not that it won't pump. It was not jamming, it was simple wedged diagnally, restricting or slowing the flow perhaps.
Last edited by Roger Trzebiatowski : 11-05-2009 at 08:34 AM. Reason: additional information
  #9 (permalink)
Old 11-05-2009, 08:41 AM
Senior Member
Default
There is a flap in the pump that when the lever is flipped one way the flap blocks water from being pumped out. When the lever is the other way the flap doesn’t block water and the water is pumped out. If the flap isn’t blocking the hole when the lever is in either position the pump is bad. This would cause it to pump when in a wash cycle like yours is doing. Note some of the pumps don’t have a rubber flap they just had a diverter but since you said you see a rubber washer I assume you have the one with the rubber flap.
The arms should be stiff as you describe.
As is said I don’t know a lot about this washer (mainly because of the age) maybe a Whirlpool tech can tell you more. I hope this helps!!
  #10 (permalink)
Old 11-05-2009, 10:56 AM
Junior Member
Default
I took a second look at the washer, it was the rubber flapper from inside the pump. I went to a local appliance store, luckily they had a pump in stock for someone who never picked it up. I purchased it, installed it, and that corrected the problem, it was a missing flapper inside the pump.
so far everything works as it is supposed to. for your information the LA7800Xp is a top loader Whirlpool Imperial Seventy super Heavy duty about 20 years old.
It still looks great and ran great, but I am sure a new high efficiency unit is in the future.
Thank you applianceman, I appreciate the short lesson in operational sequence, the problem should be solved
Last edited by Roger Trzebiatowski : 11-05-2009 at 11:00 AM. Reason: additional information
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
washer drains while agitating kevin baxter Washer Repair 3 10-30-2009 08:55 PM
GE Profile washer fills, drains, agitates, but won't spin PatrickCA Washer Repair 7 10-29-2009 05:04 PM
Must cycle multiple times to get clothes dry Windemere166 Dryer Repair 2 02-22-2009 08:02 AM
Microwave LCD multiple displays but no operation ridinpreacher Microwave Repair 4 11-18-2008 01:11 PM
whirlpool washer won't agitate fills and drains James Tysz Washer Repair 1 11-12-2008 06:03 AM
