pall820
#1 Posted : Saturday, October 24, 2015 4:49:07 AM(UTC)
pall820
LG Front Load Washer Purchased New 12 Years Ago. Ex. Clothes Get Put In Washer, Set For Normal Or Quick Wash, Turn On, Washer Fills Up But Does Not Rotate. Rather After Filling Up There Is A Humm Sound For A Minute And It Clicks Off And Displays LE ON Control Board. Opening Door To Move Clothes Around Does Not Help. Sometimes If You Press The Control Board With Your Finger In An Area Close To The Push/Pause Turn Dial A Few Times, It Will Go Into Rotate Mode And Function Ok. This Has To Be Done Right After It Fills Up With Water. You Will Hear It Kick In If You Press The Right Area On The Back Control Panel Close To The Dial. Resetting And Pulling Out Plug Does Not Help When This Problem happens. But Than Again On Some Days, It Works Fine. Problem Going On For Almost One Year. Motor Was Looked At And Wiring And All Ok. Is It The Control Back Board Or A Particilar Part Or Something Else Or Do I Need A Ghost Medium. Thanks.
Microwave LCD multiple displays but no operation (Microwave Repair)
by ridinpreacher 11/10/2008 5:28:58 AM(UTC)
