You have been a member since:: 10/29/2009(UTC) Posts: 1
Washer don't Drain, or Spin. Please Help
If you have not replaced the wax motors your board is probably toast, and you will need to replace it and the wax motors. Look at the board and see if you have some burnt spots. If you are handly around electronics and want to take the chance on repairing the board, seach this site for references to folks who will show you how and sell the parts, but be advised that there is a fair amount of controversy over whether or not to do this. If you have a newer board and changed out the wax motors you may need to replace the motor/motor control. See this tech bulletin from Maytag. http://www.servicematters.com/m...rary/docs/TDL-0018-B.pdfThe tech notice on your board is here http://www.servicematters.com/m...ary/docs/TDL-0052A-B.pdf
