My washer fills part way, then stops, and displays the "nF" error code.
I haven't been able to get it to run a quick service cycle (and I don't know if that means that it's failing the first part of the test, or if I'm simply not starting the cycle correctly). When I ran the Board Output Test, the Hot and Cold Water Valves tested fine.
I suspect that the problem is with the water-level sensor.
Can you tell me if the problem is definitely with the water-level sensor (and, if so, how to replace it), or if I need more information to diagnose the problem?
Thank you very much for any help!
