When the truck movers delivered the washer was upside-down in the truck and I found oil leaking in and outside the machine. I run a load of clothes and discovered loud klogging noises as the machine was spinning down.
Is the a "leaking Transmission" problem? Propably yoo expensive to repair for a washer that old?:(
I thank you:) Kosmas
My recommendation is to replace it and try to get the movers to pick up some of the tab.
Good luck.
