LG washer- Model# WM2501HWA...Started a wash, at the 10 minute mark, code OE ...tub full of water. Did my research, drained the tub, took out the drain motor assembly. Tested it on the bench, both motors ran on the bench...Ohms 14. Put it back together...worked for one test run, then, again stopped at the rinse cycle and would not empty...read OE. Any ideas?
