| » washer fills at drip rate |
Model Number: Maytag LA 512 Brand: Maytag Age: More than 10 years
My Maytag LA 512 fills very slowly. There's water pressure at the hose inlet. I've removed the mixer element. I can blow through the hose from the tank to the mixer. Does this machine have a pump to fill the barrel? Does it have a filter? What else might be wrong? Thanks Joe in KY
Related Models |
The water supply hoses are connected to a dual solenoid valve in the back of the machine. The solenoids are controlled by the timer, in conjunction with the temperature selector switch. It sounds like your valve is fouled up by deposits and debris from the water. Turn off the water to the machine and disconnect the hoses. You'll probably see the valve inlet screens are clogged. They aren't removable. Sometimes you can (very carefully) clean the deposits out to unclog them. At worst, you'll need to replace the valve.
__________________
Nemo malus felix |
Quote:
Right you undoubtably are. The problem began yesterday, the first load of wash since a major prumbling modification. I'll check those screens and thank you. But if I can't clean them, what have I to lose by piercing them? This is an old machine, old as I am, neither of us expect to be like brand new. Finally, any chance as to what the 'dual solenoid valve' is called in the parts books in the event I need to replace it? thanks joe in ky |
If you pierce the screens in the valve, sediment can foul the solenoid, causing it not to completely shut off. This could lead to a flood. When you look up the part, it's called a water inlet valve.
__________________
Nemo malus felix |
Quote:
ok thanks.... sure do appreciate the information. KY Joe |
| Display Modes | |
| Standpipe size and drain flow rate | suntzujr | Washer Repair | 1 | 02-12-2008 01:01 PM |
