| » Washer wont drain or run |
Model Number: WHDVH626FWW Brand: GE Age: 1 - 5 years
The washer will stop several times during a load and I have to push the start button. Also, several times the washer won't spin the water out. The clothes are very wet. The latest problem is no water drained and now washer won't wash. I can turn it on but nothing after that, just the timer runs down.
Take off the top and look behind the control module and see if there is a tech sheet. If so, it will show you how to put the machine into test mode and you may be able to find the problem.
This model is crammed full of electronics, so it can be a number of things, but pay particular attention to the inverter which controls the motor. It is a likely candidate for your problem.
__________________
| Display Modes | |
| washer wont drain | jhadz | Washer Repair | 3 | 10-05-2009 06:32 AM |
| Ge Washer Wont Drain | CONFUSED1 | Washer Repair | 0 | 03-12-2009 06:40 AM |
| My LG washer wont drain | punks1977 | Washer Repair | 1 | 12-15-2008 12:47 PM |
| Washer wont drain | Dark Knight79 | Washer Repair | 2 | 11-11-2008 09:26 AM |
| washer wont drain | jackie59 | Washer Repair | 0 | 09-26-2007 07:00 PM |
