I am having an issue with my washer not doing the spin cycle. Diagnostics came up wit the following. Stuck key, mismatch of main control and UI , basket speed sensor fault, shifter fault, motor fault, and motor unable to reach target RPM. It's a maytag washer that's only a few hrs old. I can buy a top load whirlpool direct drive for 350. It's a used rebuilt. Is that worth it.just wondering if anyone has any ideas how to fix my issues. Is it worth fixing or just replace my entire washer. Thanks in advance.
