here the problem that i am having i just replaced a bad basket drive block because after shutting the washer down during the spin cycle the tub would continue to spin until it stops after changing the drive block i notice that the tub will continue to spin just as it would before the repair as if the brakes are not working or maybe the transmission has completely gone out in just at a loss trying to figure out the cause of the problem
