Discuss
Washer failed to agitate, burning smell, humming from control panel
 in
Washer Repair
S.O.S....My washer filled as usual, but when I returned to add more clothes, I quickly noticed a
Appliance Repair Forum > Appliance Repair Help > Washer Repair » Washer failed to agitate, burning smell, humming from control panel
Reply By reading any content on this site you agree to AppliancePartsPros.com, Inc. disclaimer and Terms of Use.
  #1 (permalink)
Old 02-19-2008, 12:19 AM
ksford1 ksford1 is offline
Junior Member
ksford1 is on a distinguished road
Unhappy Washer failed to agitate, burning smell, humming from control panel
Model Number: LSQ9600LGO   Brand: Whirlpool   Age: More than 10 years
S.O.S....My washer filled as usual, but when I returned to add more clothes, I quickly noticed a burning smell, and saw that the basket was full of water, but was not agitating. I tried a different cycle setting to see if it would agitate but no luck. I changed the cycle setting to see if it would spin or do anything and it did not, but I did hear a humming sound coming from the control panel. But it was hard to tell where the burning smell was coming from.......it smelled like burning rubber and also an electrical burn as well.
I turned the machine off and unplugged it just to be safe. I came back to the machine about 15 minutes later, said a quick prayer, and tinkered around with the control knob and it work on the spin cycle, on every setting, but would not agitate and still made the humming noise at the control panel, the burning smell had subsided. The pump seems to work just fine, and the wash spun and pumped out all the water. I allowed the rinse water to fill, but again it faild to agiate, so I ran a spin cycle again to empty out all the water.
Do I have a problem with the control panel or is it the motor, drive belt, gear/agitator problem, etc.... I know I really can't complain, it's been a great product and has never needed work b4, but I'm at a loss, especially with the high cost of repairs these days. Should I try to trouble shoot it further, or should I call in reinforcements??
Thanks for any help..........Kelley
__________________
Kelley
VIEW DIAGRAMS AND PHOTOS, ORDER PARTS
  #2 (permalink)
Old 02-19-2008, 02:40 AM
richappy richappy is offline
Senior Expert
APP Volunteer
richappy is a glorious beacon of light
Default
You can go to www.applianceaid.com for take apart info. Once the outer panel is removed, pull the pump off and turn the motor shaft counterclockwise with an adjustable wrench. If it is hard to turn, you probably have a bad tranny. If ok, check the motor connector for loose wires. Please post results.
__________________
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
Washer failed to agitate, burning smell, humming from control panel ksford1 Washer Repair 4 02-20-2008 12:15 PM
burning smell wastikan Washer Repair 1 02-06-2008 11:58 AM
burning smell wastikan Washer Repair 1 02-06-2008 11:49 AM
Microwave Burning Smell TC MBK76 Microwave Repair 0 11-17-2007 06:54 AM
burning smell from inside? nanner5953 Dryer Repair 1 08-21-2007 02:00 AM
Copyright ©2000 - 2008, Jelsoft Enterprises Ltd.
1 2 3 4 5 6 7 8 9 10 11 12 13 14 15
