albuq-user
#1 Posted : Thursday, August 13, 2015 7:42:04 AM(UTC)
albuq-user
I changed the front outer tub (PN AP3773838) from my washer machine and there is a hole in the bottom front part where the washer temperature sensor is located. The hole is bigger in the new front outer tub and the seal do not cover properly the hole and it leaks.
I order a new seal (PN 8181829) and a new temperature sensor (PN 8181705) but the seal is the same size as the old one and the leak still happens.
I'm not sure if using a sealing will solve the problem because the seal has a lot of play in the hole.
795.71073.013 Kenmore Refrigerator - Water leaking in the bottom freezer (Refrigerator & Freezer Repair)
by shreshtluthra 3/16/2023 10:21:43 AM(UTC)
GE Profile PSHS6PGZBESS water leaking from dispenser (Refrigerator & Freezer Repair)
by Guest 12/30/2021 5:30:45 PM(UTC)
water leaking inside (Refrigerator & Freezer Repair)
by csegel 7/21/2020 9:15:26 AM(UTC)
water leaking IN to the tub (Washer Repair)
by gabericks 7/5/2020 2:21:45 PM(UTC)
Water leaking from freezer Magic Chef (Refrigerator & Freezer Repair)
by FabianCh 1/7/2020 5:40:04 PM(UTC)
Kenmore - Water leaking from cracked connectors (Refrigerator & Freezer Repair)
by allengl1 8/12/2019 9:02:34 PM(UTC)
Water leaking into Fridge and Freezer (Refrigerator & Freezer Repair)
by HKL64 5/27/2019 4:17:22 PM(UTC)
Frigidaire - Water Leaking from Electronic Defrost Control Area????? (Trash Compactor Repair)
by BJPrice 2/1/2018 3:20:07 PM(UTC)
Water leaking from brand new LG door in door fridge (Refrigerator & Freezer Repair)
by Jason B 7/20/2017 12:58:06 PM(UTC)
Water Leaking at Water Inlet Valve (Refrigerator & Freezer Repair)
by marshmore 12/24/2015 8:00:34 AM(UTC)
water leaking? in freezer (Refrigerator & Freezer Repair)
by chknmom 10/16/2015 3:50:20 PM(UTC)
water leaking on floor (Refrigerator & Freezer Repair)
by capetish 8/23/2015 6:39:00 PM(UTC)
Ice build up bottom of the freezer and water leaking the front door unto the floor (Refrigerator & Freezer Repair)
by BEbner 5/22/2015 1:56:55 PM(UTC)
water leaking from soap dispenser housing (Washer Repair)
by suekevin 1/8/2015 12:21:56 PM(UTC)
Water Leaking When Power Off (Washer Repair)
by TimCamden 5/30/2014 5:37:38 AM(UTC)
