lap
#1 Posted : Sunday, August 2, 2015 9:04:46 AM(UTC)
lap
It fills water but does not agitate, it will run through all cycles after including rinse, drain and spin ... Open the front panel, when it is in agitate cycle I can see the motor runs and cable turning. Is the problem with the gearcase?
Thanks & Regards
sidfink43
#2 Posted : Monday, August 3, 2015 4:04:31 AM(UTC)
sidfink43
Yes, your diagnosis is likely correct that the transmission is the problem. Make sure the belt tension is correct though and it is not just the belt slipping that is causing the problem.
lap
#3 Posted : Monday, August 3, 2015 9:11:56 PM(UTC)
lap
Thanks for the reply, I can see the belt turns the pulley okay ...
Whirlpool Mod# LSQ9200KQ0 washer won't agitate or spin (Washer Repair)
by Guest 5/13/2023 11:34:56 AM(UTC)
Washer won't agitate or spin out. (Washer Repair)
by tracibailey 1/11/2019 8:43:20 AM(UTC)
Washer won't agitate, spin, drain, but motor runs (Washer Repair)
by dmbailey0321 6/26/2018 11:36:55 AM(UTC)
Kitchen Aid Washer Won't agitate or spin (Washer Repair)
by M Yaworski 7/18/2017 7:00:37 AM(UTC)
Whirlpool Washer Won't Agitate/Spin (Washer Repair)
by Shazaam 9/1/2016 2:47:46 PM(UTC)
Washer won't agitate or spin, and motor won't turn (Washer Repair)
by Jimmm59 8/24/2015 9:59:30 AM(UTC)
Frigidaire washer won't agitate (Washer Repair)
by goosemasterkl 8/15/2015 9:37:13 AM(UTC)
Maytag top-loading Washer won't agitate, spin or drain (Washer Repair)
by coastalhousewife 6/30/2015 5:37:07 PM(UTC)
Whirlpool washer won't agitate (Washer Repair)
by jmorgan5041 6/11/2015 12:26:59 PM(UTC)
GE Profile Top Load Washer Won't Agitate or Spin (Washer Repair)
by keikomaru 3/21/2015 2:16:27 PM(UTC)
Matag Washer won't agitate, does everything else (Washer Repair)
by Jcpstrat 3/11/2015 12:00:16 PM(UTC)
washer won't agitate, but it spins (Washer Repair)
by dee021263 11/10/2014 3:22:15 PM(UTC)
GE Washer Won't Agitate or Spin (Washer Repair)
by TXTerry 9/21/2014 10:35:00 AM(UTC)
GE Profile Washer Won't Agitate or Spin (Washer Repair)
by WisconsinMatt 8/19/2014 11:34:42 AM(UTC)
Maytag washer won't agitate, but fills and spins-belts just slip (Washer Repair)
by OzarkHillbilly67 8/10/2014 3:50:22 PM(UTC)
