washer not spinning, i found a blown fuse on the speed control panel , i replaced the fuse and it blew as soon as i turned the washer on. local appliance shop said it was either the door switch or the speed control panel. trying not to waste mom's money. any clue which i should go after first or any tests i can perform to rule out one or the other? thanks, dave
