My control board went on my Frigidaire washer (diagnosed as Eb3 code - but the incoming voltage was fine) and the washer would shut off randomly during the cycles. I replaced with a used control board. When installed the washer powers on, but instead of filling with water I now get a "ddo" code for the dispensing door after pressing start. I put back in the old control board and it starts just fine (shutting off problem/Eb3 code happens sporadically). I take a look at my detergent dispensing drawer. There is no magnet for the reed switch. I don't think that there ever was. Perhaps my model did not use one? I compared the back of the two control boards and found that the new/used one has an extra 2-wire plug port that my original control board does not have (see attached image, port circled in red). What are the chances that the washer that this new/used control board came from had the detergent dispensing door reed switch and it was controlled by this port? If so, could I just bypass this by connecting the two ends with a wire? FYI, old control board made by electrolux is part # 134848200, the new/used one is #134529400. Both should be interchangeable with 137006000. Thanks for any help. This site has helped me fix my fridge a year ago.
Groups: APP Team
Hi. Both part numbers that you posted for the control board are not coming up on any sites I tried. The part number that shows up is 134855503 that crosses to the new part number 137006000. Your washer does not have a reed switch. Try to jump those two pins at the control board (if they are for the reed switch it should work). If that's not going to work I would get a new control board. Here are the breakdown diagrams and parts list for your washer: Model GLTF2940FS1
Good luck. Thank you, Simon.
