water in last cycle want cut off even when you push the control knob to turn the washer off the water keeps runing.:confused:
This sounds like the cold water valve assembly is stuck in the open position, but if the machine operates correctly in the wash cycle when the temp selection is on warm or cold for the wash cycle then it may be the timer which is not sending the close command in the rinse cycle.
What happens when you select wash cycle with cold water?
